ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Looking closer, I don't see any System or Site Quick Keys assigned to any of the trunking systems so disregard what I said about enabling them. For a test, I deleted all the conventional systems then wrote to the scanner. I see all the trunking systems ID scanning. Perhaps make sure the SQ knob is set to 2 or higher so the system won't be stuck on a frequency.
Perhaps for a test, avoid all the conventional systems then see if the trunking systems ID scans.
Nascar18
Southeast Massachusetts
Bob,
I noticed when I go to System and scroll through the list I don't see all the systems.
Reconrider
Inside the Galaxy
Radio Galaxy
For an odd reason, proscan will now not show my sds100 in the list even when it's in MSM. Tried non-admin mode, ran as admin, went in storage mode....
Nevermind I figured it out. I'm leaving this comment here(no edit, figured it out before posting) that I had VMWARE open and the program was asking if the usb goes to host or vm -_-. Dumb dumb moment
morrisr3nd
Just kind of taking it all in
Hattiesburg, MS
I've had plenty of those with this software. My own stupid fault.
Nascar18
Hi Bob, Just wondering does the "Sort" feature of a SDS 200 file effect the performance of the scanner? What should the file look like for the best performance. All the trunk systems together.
ProScan
Software Provider
Ontario, Calif.
That's more of a scanner question. I'm not sure what you mean by 'performance'. In terms of selectivity and sensitivity, no. If you mean speed, then I guess it's possible if the conventional frequencies are arranged in such as way that the scanner is constantly switching bands.
I guess the only way to find out if you could test before and after sort and report your results here.
bearcatrp
Land of 10,000 taxes
Looks like my issue has come back. Seems to kick the SDS200 off the screen around 2 am every day. I have to turn off/on for proscan to record again. On Win10. Looked through the settings but don’t see anything that could cause this. There was an update for win 10 shortly before this cropped up again. Scratching my head on this. Any ideas?
ProScan
Software Provider
Ontario, Calif.
I don't know what issue you are referring to. Is it the audio and/or data input? Are you using the scanner LAN port?
bearcatrp
Am using the Lan port. The software is active but we’re the SDS 200 shows up on screen, it’s blank. Sometime after 2am it goes dark. The last recorded transmission is a little after 2am. I shut off the SDS200, turn it back on, and things are normal. I have fiber optic to the house. What’s weird is after having this issue before, an update for win 10 came out, I stopped having this issue. Another update came out a few weeks ago, and this started again. For now, I have to reboot the scanner every morning.
ProScan
Software Provider
Ontario, Calif.
Do a online search 'log ethernet down'. Many pages on the subject. Also want to check your router log.
