ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
ProScan Version 5.3 Is Out
This release is mostly for those that use the Scanner Over IP feature. The audio quality is improved with the addition of streaming and receiving mp3 audio.
ProScan Version 5.3
  • Added - Remote Scanner Over IP - MP3 audio format.
  • Added - Export HTML and CSV File - "System / Site / Search Quick Keys" section now shows the Group Quick Keys assignment.
  • Added - XT Series - UID lookup text tags from file.
  • Fixed - Web Server - In some cases, the port number is not included in the "Listen Live" link and can't listen using a media player.
  • Fixed - Recorder - Scanner Over IP Client side various problems.
  • Many more small improvements.
Free Client will be released later this week.
At this time, there are no known bugs or issues.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
lep
Hmm, v 5.3 appears to download and extraction of files seems ok. However, when I attempt to "run" I get an error message that "client does not hold privilege" or words to that effect.
I am using v 5.2 and had no problems when upgrading previous versions to 5.2...
Am I doing something incorrectly?
LEP
lep
For reasons not clear to me, v 5.3 installed w/o the dreaded error message and appears to now be working as advertised.
crevatis
Kenosha, WI
5.3 Breaks remove scanner over IP
The stop button is greyed out after starting the server, and the clients gets the audio, but display data from the scanner does not appear.
MilAirNJ
South NJ
Remote over IP greyed out
Same problem here. 5.3 shows the start/stop button greyed out. When trying to use remote over ip! I am using windows 7
Adenosine
Bangor, ME
Why is Proscan racking up the miles? Opened Task manager to find ProScan eating 355,000k of my memory. have restarted my computer and restarted ProScan. Its back up to 85,000k and climbing as I type.
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
I've never looked before, but I concur with Adenosine. As I watch ProScan via Task Manager (Windows 7 32 bit) I'm noticing it increasing in primarily 4k increments. Occasionally it falls off by a small amount and then starts counting up again. This is using the latest version.
ProScan
Software Provider
Ontario, Calif.
New Version 5.4 For Scanner Over IP Testing
For anyone that uses the Remote Scanning Over IP feature:
I found some major memory leak problems with the mp3 decoding that was introduced in ver. 5.3 and some other SOIP problems on both the server and client side. Hopefully these files are production quality.
ProScan full version
http://www.proscan.org/ProScan_5_4_Test.zip
ProScan Free Client
http://www.proscan.org/ProScan_Client_5_4_Test.zip
Unzip the executable and copy over the original executable.
Repoting bugs:
OS and 32 or 64 bit
Server or Client
Options turned on
If possible, the server URL & port number so I can try to connect.
Via email, I can respond with more questions and send files until bug is fixed.
Adenosine
Bangor, ME
Is the memory leak problem why ProScan is using more RAM?
I have ver Proscan 4.6 on win xp. Im not using Remote Scanning Over IP, I'm just providing feed to RR.
ProScan
Software Provider
Ontario, Calif.
More RAM may be due to the logging of the history and recording data. Streaming to RR is stable and time tested.
ProScan
Software Provider
Ontario, Calif.
You can press the start button in 5.4 and start the server, but 5.4 client doesn't connect.
Need more info.
Repoting bugs:
OS and 32 or 64 bit
Server or Client
Options
If possible, send me the server URL & port number so I can try to connect.
ProScan
Software Provider
Ontario, Calif.
SOIP - Need more testers
I need more testers for the Scanner Over IP feature, server and client before I'm satisfied the connection problem is fixed and can move to another area of ProScan.
I had three reporting success and one that advised that it failed on a WAN but a LAN is ok. ProScan doesn't differentiate LAN & WAN.
Unzip and copy the executable over the original executable.
ProScan full version - http://www.proscan.org/ProScan_5_4_Test.zip
Email me the results and I can send test files if needed.
Reporting bugs:
OS and 32 or 64 bit
Server or Client
Options
rmosier
Mt. Olive,NJ
I am running the "Scanner over IP test" now.
My IP is
173.3.116.22
NJ (Morris)-MIRS,Municipal:pD,EMS,FIRE.
So far I am unable to connect from the same PC that supplies the feed ( I used to be able to).
when trying to connect it returns the error "unable to access comm port 3"
Please let me know if there is anything I can do to help.
Ray
ProScan
Software Provider
Ontario, Calif.
My IP is
173.3.116.22
Ray
Why can't you access comm port 3? Does the Windows Device Manager show comm port 3 assigned? Does another program has port 3 opened?
ProScan
Software Provider
Ontario, Calif.
This release is for anyone using the Remote Scanning Over IP feature. The testers are reporting the connection problems are fixed.
  • Added - Remote Scanner Over IP Option - Don't prompt "Clients Connected" message when stopping the Scanner Over IP Server.
  • Fixed - Remote Scanner Over IP - Client & Sever side connection problems that got in during 5.3.
  • Fixed - Remote Scanner Over IP - Client side memory leak that got in during 5.3.
