ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
robsterw
St. Johns, Newfoundland, Canada
Hey Bob,
Excellent job on the new version of ProScan.
Curious if there are plans in future to support the Uniden BC125AT scanner?
It would be perfect for streaming/recording alpha tags on conventional analog systems on the cheap.
MilAirNJ
South NJ
Proscan 5.5 web server problem
the Webserver runs great with one person listening. But a 2nd person is unable to log in and listen. I even set the maximum connections to 10 to be sure..
I am running Windows 7 Home Premium 64 bit
ProScan
Software Provider
Ontario, Calif.
When reporting bugs, always advise on the product(ProScan, Free Client, or RadioFeed), version, OS type, scanner type, and options pertaining to the bug. Describe in detail what the bug is doing or not doing.
MilAirNJ
South NJ
Proscan Client 5.5
Proscan 5.5 (Paid version) Version 5.5, Windows 7 64 Bit, BCT15x.
Two people can not listen to my web server at one time. If one person is listening, then second person trying to access my web server gets a time out!
Tried on multiple different browsers
http://acpd.bounceme.net:1112
To recreate the bug try logging into the above address from two separate computers.
Thanks in advance
ProScan
Software Provider
Ontario, Calif.
Thanks in advance
Thanks, I'll look at it before the next release.
upstatesc
I've been using ProScan registered for two weeks now. This morning it randomly crashed on me, and when I restarted it all of my settings were wiped out. I had to do everything over again- COM port, record settings, etc. Any ideas why, and can I possibly back up the config file to prevent this from happening again in the future? Now none of my recordings are listed anymore either, I have to manually browse to the folder they are stored in and play them back with Windows Media Player.
ProScan
Software Provider
Ontario, Calif.
Don't know why it crashed without any details. Being Tuesday, do you have Microsoft Updates set to automatically install updates? I've seen in the past a graphics and audio drivers installed part of the Microsoft updates. Not saying that is the problem, In the past I've seen three reports of this type of problem suspecting a driver.
The ProScan.cfg file is saved when the program closes. You can close the program to save the cfg file and back it up.
SABER3
Saber3
Audio files
I have been using free scan for at least 3+ years with a BC 996T 396XT and 996XT on a windows xp machine that failed. put it on my new dell running windows 7 64 and i cant find the folder with the recorded audio files.in xp there was a neat folder for the audio-just open it up and port whatever i wanted into windows media player. i cant find the folder that contains the audio on the computer. i also cant find the proscan folder either. would appreciate any help.
there is also a weird problem with the recording. if i exit the software before turning off the radio, i have to enable the audio control by going into the controler and highlighting the mic icon, then exit the program and re start it to get the recorder to work. if i shut the radio off first and then exit the software, the record button bar works coreectly.
the other weird problem is i cant delete more than 2 pages of old recrdings if i choose the each file in new line option. i can dump about 50-100 lines per session, then it remove selected line doesn doesnt remove the lines.
i like the program. some of the button bars are cramped. i wish you could actually control the radio with the button bars, turning on and off systems.its nice that the squelch and volume keys can be controllrd via software.
SABER3
Saber3
ps have version 5.2. dont want to update as all the updates have been for remote control. dont need that function right now.
ProScan
Software Provider
Ontario, Calif.
Win 7 64 bits treats the \Program Files (x86) folder differently. Using the Windows Explorer, navigate to the sub folder under \Program Files (x86) and click on "Compatibilities files" and then you will see all the files.
ProScan
Software Provider
Ontario, Calif.
Version 5.6
ProScan Version 5.6 Release
  • Added - Web Server - Web page link showing a list of parameters that can be retrived by external programs.
  • Added - Web server - Display metadata in RealPlayer using a workaround due to a RealPlayer bug.
  • Added - Web Server - Burst buffer for eliminating buffering when media players start to playback.
  • Added - SOIP Client - Published servers list save sort order when closing program.
  • Changed - Database - Menu items were grayed out when the database was not opened. Now a message to open or create a new database.
  • Fixed - Web Server - Only one player could connect at a time.
  • Fixed - SOIP Server - Start button may stay grayed out after starting.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
MilAirNJ
South NJ
Service Search-Military missing
Service Search-Military is missing under the "Jump" button for the BCT15x.
It is accessible directly from my scanner though.
lep
Lost UID lookup file
On Jul 4 my C:/ drive had a catastrophic failure. Now replaced with new PC and Win 7 OS. Downloaded paid v 5.6 which is running fine with my BCD996XT. No longer can locate documentation on how/where text is to be entered for UID alias lookups, to me a key feature for the user. I recall char % is needed somehow but don't find explanation, need SAMPLE/Dummy lookup as I *am* a computer dummy and also don't know what the proper address should be for the file.
ProScan
Software Provider
Ontario, Calif.
1. Prepend a "i" to the TGID and prepend a "%" to the TGID text tag.
2. Upload the change to the scanner.
3. Go to the logging options and click the logging tab. Press the "UID Text Tag Lookup File" button.
4. Edit the file and close it.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 5.7
This version 5.7 release is mainly for those that use the Web Server feature. Cookies should be enabled to log in and JavaScript should be enabled for automatic updates.
  • Added - Web Server - Web page automatic update interval option. Updates parameter page, current listeners, peak listeners, and client connections(administration page).
  • Added - Web Server - User customization of the web server page by editing the style.css file.
  • Added - Web Server - Administrator password & administration page. At the moment, only shows the client connections.
  • Added - Web Server - Better looking HTTP error messages.
  • Fixed - Web Server - Burst buffer was causing some media players not to connect intermittently.
  • Fixed - BCT15X - Service Search - Military was missing from the Jump button.
smason
Alberta Canada, Eh!
[*]Fixed - Web Server - Burst buffer was causing some media players not to connect intermittently.
Ahh good news. I JUST upgraded from 4.47 to 5.6 and was having intermittent problems connecting with my iPhone using FStream. Hopefully that takes care of it. I'll upgrade tomorrow.
Speaking of iPhone apps,
FYI:
ActionScanner no longer works. I suspect it's because the stream path changed from /stream.m3u to /ProScan.m3u
I changed it in FStream and it works. ActionScanner ignores the /ProScan.m3u and insists on stream.m3u.
ProScan
Software Provider
Ontario, Calif.
FYI:
The stream name was changed from stream to ProScan 10 months ago. I wasn't aware that is an issue. I can change it.
smason
Alberta Canada, Eh!
Yeah, I was a bit behind in my updates :)
Thanks. It only seems to affect ActionScanner. Not sure how many people would use that with ProScan.
I wouldn't mind being able to use it again.
