ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
justlen
You may think the problem is with ProScan because it works after restarting ProScan. I think it works after restarting ProScan is because the Windows API WaveIn closes then reopens. If it happens again, Set the Input device to none then back to the device using. That will close the WaveIn and reopens it. I think something in your OS is doing it. You may want to look into a USB audio device to solve the problem.
I finally chased it down. In the Device Manager it's the "Allow the computer to turn off the device" in the Root Hub (not the USB device itself). I also had more than one Root Hub.
My audio has been recording for a week now. Thanks to everyone for the suggestions.
JimD56
KO9JAD/Retired-Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
I want to run 2 TWO SDS200s using the REAR LAN Ethernet into ONE LAN Ethernet connection on my PC, NO ROUTER.
Is this doable? Will an Ethernet Splitter work?
I only want the screen and control, the same thing the front micro USB would do but I want the cables hidden, so I don't want to use the front.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Pretty sure the rear port is an RJ-11 and only for the GPS. But yes, you can use the RJ-45 in front and get a cheapy switch and do it that way.
N9JIG
Sheriff
Moderator
Far NW Valley
The rear port is for GPS, not an Ethernet port.
I used a thin CAT-6 cable with a downward facing angle for my SDS200's, this pretty well hides the cables:
JimD56
If anyone knows a link for a really thin right angle down USB micro cable post it here please.
Since I have to go through the front of my SDS200s I only need the micro USB.
I'm in the middle of building out a "new rack" .
Jim
N9JIG
Sheriff
Moderator
Far NW Valley
Jim
This is the USB cable I bought. Works great!
In case you were wondering, this is the Ethernet cable I got:
ProScan
Software Provider
Ontario, Calif.
Hey Bob. Just a food for thought/question. How hard would it be to implement a dark mode option onto the ProScan software? Just was curious of the extent, so it's not like a flashbang going off when you open it up at night or dark times. LOL. Thanks! @ProScan
It will take a long time to do so I probably won't do it.
ProScan
Software Provider
Ontario, Calif.
I am trying to connect proscan to my Icecast server but unfortuantly it does not have a spot for a username only password
No username input as 'source' is always the username and it's hardcoded.If you're trying to log in to the admin page then that has nothing to do with ProScan and therefore no username box.
{edit} Are you seeing a message when trying to connect to Icecast?
ogppc
Merced County CA (West)
Sorry to be a bother but I have a question.
I'm running ProScan on a 780XLT and the display and responses from the software appear to be a bit sluggish. Baud rates are maxed out (yes I checked that) and also tested two different computers and two different serial adaptors, along with just a standard serial port on the laptop (thank god Toughbooks still have real com ports)
Any suggestions or is it just something that needs to be put up with when using a bit of a dinosaur for a radio? It works great for me with the newer radios.
Any suggestions will be tried and are greatly appreciated.
rlex
Hello, is it possible to record per-uid, and not a full conversation? I want that to fill my UIDs database. It's kinda hard when you heard conversation between several stations, but you only see one UID in recordings.
ProScan
Software Provider
Ontario, Calif.
Net yet. A UID Recorder feature is tentatively scheduled for the next release.
rlex
Great news!
And any chance you're planning excel-like editing (or just copy/paste support) in favourites editor? It will be nice for some mass-adjustment. Currently i'm using sentinel for that, but it will be nice if i can ditch it completely. It seems like i can copy from ProScan to LibreOffice Calc, but i can't paste it back.
Oh, and another tiny idea about excel-like - search in "history" and recordings tab, so you can quickly find specific dept/system/channel etc, which will filter lines by user input.
ProScan
Software Provider
Ontario, Calif.
Great news!
{edit}
Whay kind of "mass-adjustment" How are you doing it in Sentinel?
Subimit a suggestion.
Suggestions
rlex
Just Ctrl-A Ctrl-C in Sentinel (TGID list, Channel list, Station list, doesn't matter), then Ctrl-V to calc/excel, edit what i need (ie initially i was filling UIDs with districts, but since district is already visible in TGID, i decided it was redundant, so i just did mass search & replace, removing district from UID name), then ctrl-v it back to sentinel. Save & Send, done.
Will send suggestion a bit later.
ausscan
Not sure if it has been raised, I noticed on 22.12 where a user connects to the Web Scanner via a reverse proxy the IP address of the user was meant to be shown.
Is there a setting I have missed as I am not getting the end user IP only the proxy IP address?
ProScan
Software Provider
Ontario, Calif.
What was the last version that worked? Can you revert back to the previous version to see if it does the same thing. At this point, I don't believe any changes were made in 22.12 or 22.11. Perhaps email me a Bug Report so I can send you test files. That being said, I'm in the middle of another area at the moment so it will be some time until I get to it.
Version 22.10
  • Changed - Web Server - Using a reverse proxy now shows the client IP address and not the proxy IP address.
