ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
W5RGP
Charlotte Tn
What email address can I use to have my
Pin resent to me I am a registered owner of pros can
Installed on laptop it crashed reloaded windows hard drive went out so lost my info
Sent from my DROID RAZR HD using Tapatalk 2
nyair1
Proscan remote setup
I have been reading through the instructions on how to setup my radio to braodcast over the internet. I don't know alot about this and seem to be having a problem with the web server setup. I picked a port number and tried to test the connection per the instructions but it won't bring up my local ip when you click the get ip box. It does show my outside ip but i can't figure out what is going on. I have tried a few different port numbers and still no luck?? I would like to be able to remotely listen to my radio at work or in my house with my laptop using the client proscan. Is there anymore basic instructions?? I don't know much about this. Thanks
ak4fn
Fredonia, KY
Have you forwarded the port in your router?
ProScan
Software Provider
Ontario, Calif.
When you say "client". Do you mean the Remote Scanner Over IP Client? That is for connecting to the Remote Scanner Over IP Server. You can use the Web Server or Remote Scanner Over IP Server. Setup is the same. Web Server is for Web browsers to connect.
Same question that ak4fn asked...Have you forwarded the port in your router?
rmosier
Mt. Olive,NJ
I'm using version the latest version. Some time after I start the program (an hour or two sometimes) it's CPU usage will climb to 90%. What's that all about?
nyair1
How do i go about that?
alwayslookin
Southern Indiana
You need to go into your router settings and setup a port to be forwarded by typing your routers ip address in your browser should be something like 192.168.1.1 type in user name and password some default user name is admin and the password may be the same, check with your routers website and that should tell you. then go to port forwarding tab and setup a port to be used. Hope this helps.
ProScan
Software Provider
Ontario, Calif.
What's the make and model of the router?
Are you trying to get the Remote Scanner Over IP Client or Web Server to work?
Before you setup the router Port Forwarding, you should test for connectivity locally (or on the same machine). Locally the IP address starts with 192 or 10 and doesn't require the router Port Forwarding setup. Advise when you got the local connection to work.
Get back with me on my questions and I'll google search the make and model of the router. Two key items that's goes into the Port Forwarding: The port number which is the same as the number you have in the ProScan Server Port box. The other item is to configure the Port Forwarding for TCP.
nyair1
What i am trying to do is set-up my home scanner that is running proscan and be able to listen to it at work over the proscan client software that you have. I'm not sure if i'm going about this the right way?? Do you have a setup guide to help me with that?
I will have have to check tonite when i get home on the make and model of my router. Thanks for the info so far guys.
ProScan
Software Provider
Ontario, Calif.
Setup is in the help file. First determine if you want to use the Web Server which doesn't need a ProScan client, just a Web Browser or you want to go with the Remote Scanner Over IP feature which offers logging and recording capability. Setup of the Web Server and Remote Scanner Over IP is the same. Port forwarding setup is different for each type of router so I would consult with your router documentation on that.
nyair1
Now if i use the Proscan client software i would be able to have control of my scanner at home while im at work? I would like to able to do that if possible. Am i looking in the proscan help file or the client help files for set up? I will hopefuly have somemore freetime over this weekend to sit down and play with it more. I will have to dig around for my router instructions. I belive it is a Belkin model. Not sure of which one off hand. Thanks for the info.
ProScan
Software Provider
Ontario, Calif.
The Client has more control then the Web Serber as you can download and upload. The Web Server has a virtual keypad control.
The ProScan file because you are setting up the server. The client doesn't have a server so it wouldn't be there.
nyair1
Ok now my home scanner is a bc780xlt. So i should use the "Remote scanner over IP" tab on the proscan software and follow those instructions to be able to have control of it from my work computer?
I have a Netgear N150 wireless router model #WNR1000 running off my Time Warner cable modem. I also have a Netgear universal wifi range extender model #WN2000RPT to extend the wireless in my house. I logged into the wireless router setup but i cant find anything for port forwarding? Thanks
lost_in_maine
Western Maine Mountains
Did You get the Router from Time Warner?
Some ISP's Firmware disables the option to port forward..
