ProScan
Software Provider
Ontario, Calif.
Bob
Magpie
Great version Bob. I love the Lockout and Temp Lockout added to the Resume Scan / Search function.
I don't understand the Notch Filter function. Can someone please explain how to use it and what it does?
Mtia.
INDY72
Indianapolis, IN
Notches out unwanted ones etc. Like the end tones on EDACS comms or possibly MDC1200 tones
Sent from my LG-K330 using Tapatalk
Magpie
Disregard my request Bob. Ones running one can go back to regular layout where everything fits nicely.
Have briefje tested Custom Search with Auto Temp L/out set to ON. Works perfectly. Many thanks another great improvement in scanner monitoring :)
ProScan
Software Provider
Ontario, Calif.
So I'm really hoping Proscan has added full BCDx36HP support so I can use One Ring To Rule Them All.
Anyone? Bueller?
If you're asking me. Any request that takes more than 10 minutes to do should be by email. That way I can organize, prioritize, ask questions, and send out test files. Perhaps if your request was initially via email, it would of been done already but other request would not of been done.
Some want to be vocal and apply public pressure, I don't work good under pressure and tend to go on to other things. When anyone makes a request via email without the drama or commentary, it goes higher on the priority list whether I like it or not.
LE_SECTOR
Proscan 12.3 Installation Error
Greetings, while updating from Pro Scan 12.2 I encountered the following error message. Using windows explorer, there is no Proscan.exe file in the Program File (x86) folder. Using ABORT shows rolling back changes but Pro Scan no longer executes. A great app that I have been using for several years is dead in the water so any help is appreciated.
Regards,
plaws
E Hawkesbury Twp, ON
You've clearly missed my point, so let me be direct: Does Proscan fully support the BCx36HP radios the way it does with the XTs, P2s, etc? It did not last I checked. That's fine. Has the capability since been added? That's all I want to know.
ProScan
Software Provider
Ontario, Calif.
Your point wasn't very clear and your question changed.
ProScan supports Favorites editing but not Profiles.
It seems like you already know the answer when you last checked. If anything else, let me know.
dss56
Boston
I wanted to try the proscan SW in the 30 day trial. Every time I try to install and start the program I get a window that says the 30 day trial has expired. This is the first time I tried to install in my computer.
Can someone help so I can see if I want to buy the program.
thanks
ProScan
Software Provider
Ontario, Calif.
thanks
Helped via email.
radiochuck
Traffic Reporter
Phoenix, AZ
I love ProScan. I use it at work and plan in getting another license for home.
I have a weird issue with the latest version, 12.3. When I launch the 'Number Tag Tune' function when ProScan is maximized, the dialog that pops up is halfway off the right side of the screen. Any way to prevent this, so that I don't have to drag the window back in each time? I appreciate the help.
ProScan
Software Provider
Ontario, Calif.
I'll fix it before the next release.
radiochuck
Traffic Reporter
Phoenix, AZ
These may have been mentioned previously, but:
1. Under the Database --> Quick/Search Keys tab --> Group Quick Keys Status section, a complete listing of all systems do not appear in the dropdown
Same. Ver 12.3.
I also found in a few instances that GQK 9 is showing as "not assigned." I think I saw that someone else had mentioned that.
Thanks!
