ProScan
Software Provider
Ontario, Calif.
Bob
GTR8000
NY/NJ Database Guy
BEE00
ProScan Version 19.5 Just Released!
This is another small release. I received many emails on these two items so want to get this out before I finish the next feature and finish the VOX Recorder program.
Sorry, Bob, I hate to be "that guy" dredging up an old post, but I must've missed this from back in June and don't recall seeing this mentioned. Are you planning on creating a standalone VOX recording program? If so, that would be sweet. I've been using an ancient copy of SRPro for many years, and while it has served me well, it would be nice to have a more modern VOX recorder that is actually supported. Thanks, sorry to go slightly off-topic.
ProScan
Software Provider
Ontario, Calif.
Glad you asked. I did make it a few months ago. I've had a few testers and they reported favorable results.
VOX Recorder
GTR8000
NY/NJ Database Guy
BEE00
Excellent, thanks! I'll take it for a test drive and will report back. I had planned on using it just for local recording, but now that I see it supports the Calls platform, I'm intrigued.
Edit: Ah okay so it won't record locally unless a Calls API key is entered.
ProScan
Software Provider
Ontario, Calif.
Off hand I think it should.
GTR8000
NY/NJ Database Guy
BEE00
No worries...incentive to apply for a Calls node!
It would be handy to use standalone without a Calls node, so I'll put in a request to record without the API on Github if that's okay with you, rather than my further derailing this ProScan thread. :oops:
ProScan
Software Provider
Ontario, Calif.
I'm not going to have time for the foreseeable future to work on it as ProScan is taking up most of my time. The source code is posted so anyone can modify it.
03msc
RF is RF
The Natural State
This is what the Modify Uniden Database feature is going to look like in the next version. It's just about ready.
So I'm going to be the one who shows their ignorance here but what would be some real world use cases for this? Is it simply to be able to correct/change info that is in the database? I guess previously it was only able to be done if the information had been imported into a Favorites List but this allows modification of the full db without importing into a FL?
JohnSC
Greenville SC
There may be other uses, but my example is the road trip. I use the global database and satellite tracking on my SDS radios when driving the interstates. Not interested in the local law enforcement chatter, just the highway patrol, fire and ambulance TGIDs. The screens are impossible to read while driving, so I rely on the Alert Color codes.
Two issues with the global database: local and state law enforcement agencies are grouped under Service Type Law Enforcement, and there is no Alert Color coding. Let me quickly do a hats-off to the folks who maintain the database. We wouldn't be here if it were not for them.
The Proscan find and replace would allow me to "Avoid" service type "Law Enforcement" with one sweep. Next, TGID "Highway Patrol" would be assigned service type "Custom 1" (to dodge the Law Enforcement avoid), and the alert color would be green (my example), service type "Fire Dispatch" becomes Alert Color red, and "EMS Dispatch" becomes yellow.
With three or four tweaks, I customize my SDS100 or SDS200 for the vacation beach trip across the Carolinas. My wife is pleased that the background chatter has been reduced on an hours-long trip, I no longer strain to read a screen that takes my eyes off the road. And I am not missing HP traffic because of a local traffic stop on a back road or city street. At the beach, I turn on my Favorites List until I start back home, which is a quick changeover. And, when I get back home, I turn on my local FLs.
There is nothing here that couldn't be done with the FLs, with considerable tweaking of a dozen county locations and law enforcement jurisdictions. Switching Service Types doesn't work because there is no differentiation between city, county and state law enforcement, all bundled under "Law Enforcement." And, of course, the global database has no color coding by Service Type, which should be considered by the powers that be.
This is not a perfect solution: the next global update of the database wipes out my tweaks. It is possible to copy the state hpd to a safe directory and move it back after the update, but then I miss anything new in my state database. And, we have not seen the finished product, although I am confident the upgrade will do the trick.
03msc
RF is RF
The Natural State
OK, excellent example. I see the benefit now. I was understanding what it could do but, in my mind, I wasn't seeing the benefit but now I do. Excellent. Carry on and happy tweaking, all!
ProScan
Software Provider
Ontario, Calif.
I've seen a few posting over the years that the full database can't ID Search on trunking systems so that may be a useful function. It's not perfect if the Uniden weekly pull determines that a system is not "scannable" because no TGIDs in the radioreference database and therefore the system will not appear in the Uniden database. I've also seen a few postings asking about text center justifying and letter capitalization. During testing, I used the System Avoid to avoid all conventional systems.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 19.7 Just Released!
  • Added - Find & Replace function added to the Modify Uniden Database utility.
  • Added - DMA and HP scanners - Nodes in the database/favorites tree now will show avoided/locked out in color red.
  • Changed - Moved the various items in the Modify Uniden Database utility to individual tabs.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
N1SQB
Somewhere On Earth
Upgraded to the 19.7 version. Now, even after updating the driver and refreshing the ports, it refuses to see a port. The device manager says the cable is working properly. I have restarted the computer twice. Still nothing. Furthermore, now I am trying to use other software (sentinel) to update the SDS200 and I get an error code. ( see below). I had NO issues prior to the update. The only thing I have done differently is update the Proscan software. I don't get it..Someone explain this to me if you can, I'm out of options on my end.
Manny
GTR8000
NY/NJ Database Guy
BEE00
Manny
Did you try power cycling the scanner?
The error message in Sentinel is completely unrelated to ProScan.
ProScan
Software Provider
Ontario, Calif.
Manny
No changes in ProScan in this area. Power cycle the scanner and see what happens. If it still happens then check the cable and driver. The Device Manager "This device is working properly" message is not that reliable.
N1SQB
Somewhere On Earth
Did all you suggested, but still nothing. I changed cables, nothing. It still shows "none and URL under port choices in the software. The computer at times refuse to show that there is even a cable plugged in.
Manny
ProScan
Software Provider
Ontario, Calif.
Manny
Did you install ProScan in another folder? If so then another instance of ProScan may be running. Check if more then one instance of ProScan is running. The 1st instance may be using the port and only 1 app at a time can use the serial port.
N1SQB
Somewhere On Earth
Did you install ProScan in another folder? If so then another instance of ProScan may be running. Check if more than one instance of ProScan is running. The 1st instance may be using the port and only 1 app at a time can use the serial port.
No sir, just one folder, I just checked to verify. I am stumped at this point. I have been using the same cable for over a year without any issues.
I wonder if it's something with the scanner itself. I tried the clear user data thing and still nothing. When you first plug in the cable, you can see it in device manager. Then as it goes into USB mass storage mode, you hear the sound of it disconnecting from the computer, reconnecting, then the LPT Commports disappears from device manager.
ProScan
Software Provider
Ontario, Calif.
What type of scanner? If you see only None and not the port numbers in the Comm. Port Settings, the comm port numbers are coming from OS and in that case, reboot the computer. Power cycle the scanner after the computer finishes rebooting.
{edit} If you changed cables per your post in 7616, change it back.
ProScan
Software Provider
Ontario, Calif.
I wonder if it's something with the scanner itself. I tried the clear user data thing and still nothing. When you first plug in the cable, you can see it in device manager. Then as it goes into USB mass storage mode, you the sound of it disconnecting, reconnecting, then the LPT Commports disappears from device manager.
Is it going into Mass Storage mode by itself? It's not suppose to do that. If no keys are pressed then it is suppose to go into the serial port mode after a timeout.
