ProScan
Software Provider
Ontario, Calif.
Bob
garys
Central Texas
I've only had a few minutes to play around with Profile Editor, but I like it. Much easier than Sentinel.
I got warnings about no valid certificate, but clicked past those and downloaded and installed the update. The first time I tried to read the profile out of my SDS100 I got a schedule exception warning, but clicked past it.
I tried it again expecting to get that warning, but it didn't happen, so I can't copy and paste it here for Bob to look at.
Other than that, I like it. I'll read out my SDS200 info to see if the program uploads the location information.
Chris0516
Pittsboro, North Carolina
To me, at least. I think of Proscan, as. The GOLD standard. You can't go wrong with it (y) (y) (y) (y) (y) (y) (y) (y) (y) (y) (y) (y) (y)
Whiskey3JMC
Simulcastylvania, TE
Next version is going to have a Profile Editor very similar to the one in Sentinel.
Just when you ask "How can Proscan get any better?" Bob promptly answers that question & delivers! Best software app I've ever used for any radio, ever! How do you do it? (y)(y)(y)
ProScan
Software Provider
Ontario, Calif.
Folks,
The Profile Editor is just about completed. Let me know how it works out. I don't see any issues at this time.
To access the Profile Editor, click the Profile Editor check box located in the menu on the left side
Improvements over Sentinel
  • Can be used standalone or called from ProScan
  • Location Settings tab - DMS format 4 decimal places to minimize rounding errors
  • WinForms and messages centered over the app
  • Improved Waterfall and Display Customizer color picker. Colors sorted by HSL and not color names
  • Buttons to 'Check All' & 'Uncheck All' on most grid checkboxes
  • Removed the 'Search With Scan Options' as I believe the system and department labels are mislabeled and the options in the Search With Scan dialog 'Avoid' & 'Hold Time' should belong in the Custom Search grid
  • All favorites options can be changed in the Scan Selection tab
This test version 23.9.1.0 compared to last test version 23.9.0.0
  • Dark Mode
  • FTP Read & Write
Fixed - Option 'Clicking Speaker Icon Mutes All Instances' broke in ver 23.4
Unzip and copy the files over the original/s.
http://proscan.org/ProScan_23_9_1_0.zip
Profile Editor supports the BCD436HP, BCD536HP, SDS100, SDS200, SDS100E, SDS200E, UBCD3600XLT, UBCD436PT, UBCD536PT, & USDS100 scanners.
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
Am I reading the manual correctly for the Broadcast L/O, that I could have channel such as a med patch to hospital in my scanner feeding audio to proscan and it will still record it but not pass it on to broadcastify when put inside the file?
garys
Central Texas
The Profile Editor is very impressive. The only thing that I would like to see is being able to resize the window as we can with the Favorites Editor. Not a big deal, but it would be helpful for these old eyeballs.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 24.0 Just Released!
  • Added - Profile Editor for the BCD436HP, BCD536HP, SDS100, SDS200, SDS100E, SDS200E, UBCD3600XLT, UBCD436PT, UBCD536PT, & USDS100 scanners.
  • Fixed - Option 'Clicking Speaker Icon Mutes All Instances' broke in ver 23.4.
Profile Editor improvements over Sentinel
  • Can be used standalone or accessed from ProScan
  • Removed the 'Search With Scan Options' as the system and department labels are mislabeled in Sentinel and the options in the Search With Scan dialog 'Avoid' & 'Hold Time' should belong in the Custom Search grid
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Whiskey3JMC
Top notch release as usual, Bob but just one question: Is there a reason why there's no "Set MSM command to scanner" button if you choose Scanner Read or Scanner Write from the Profile Editor? Had to go into my Favorites Editor to send the MSM command1750977145379.png
hazrat8990
Wyoming
I'm loving this version! One thing I noticed while messing around with the profile editor is that when you try to write to the scanner via FTP, the scanner goes into FTP lock mode and restarts (as expected), but it doesn't actually write the profile. However, it will write the profile just fine if the scanner is in MSM, and you select "scanner write".
ProScan
Software Provider
Ontario, Calif.
I'll look at it before the next release.
Chris0516
@ProScan When I upgraded to v24, the Favorites Editor reacted fine, opening the database file for my SDS100, but.
When I clicked on 'File' in the Favorites Editor, for my BCD436HP, I got this:
System.NullReferenceException: Object reference not set to an instance of an object.
at MyFolderBrowserDialog.set_SelectedPath(String value) in \ProScan\MyFolderBrowserDialog.vb:line 368
at DynamicDatabase_C.OpenMenuItem_Click(Object sender, EventArgs e) in \ProScan\Data_C\DynamicDatabase_C.vb:line 6618
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Any idea why this happened?
TIA
ProScan
Software Provider
Ontario, Calif.
TIA
It's fixed. It will be in the next release.
TFOX9
TFOX9
Bob any news yet on getting this fixed on the other scanner the Uniden BCD996P2 it dose not do this at all now i do realize that the Uniden BCD996P2 is a much newer scanner then the Uniden BCD79D but again i have no problems at with the other one only the BCD79D and iam doing everthing right to here's a another screenshot of the trunk type on and already to go if you can help in any way i would really appreciate it Bob From Tom. oh one more thing the input radio referencemenu ui no longer disappears whenever iam going from tab to tab no more ty ty for that Tom.1751426075266.png1751425628772.png
