StarCom21 2024 Official Thread
officerdave
Retired LEO
I'm told by a long-time Bloomington-area listener that ISU operations (other than campus police) had previously used the Cleartalk system. He gave those legacy ISU Cleartalk talkgroups a listen for a day and a half and heard no activity. He believes that the new STARCOM21 talkgroups (in the 4031-4050 range so far) are likely the ISU operations (dorms, heating plant, Braden, Horton, golf course, grounds, etc.)
that used to be on Cleartalk.
Explains why ISU bought a boat load of used APX 7000s from DuPage ETSB. 7/8-UHFs
K9KLC
Southwest, IL
Maybe not the correct place to ask but would the unication be a good choice to monitor the Madison county simulcast on Starcom 21?
cubn
Marion/Johnson County, IN
I have not listened to that particular site but I have listened to Indianapolis and Champaign Illinois which are simulcast systems that my 396 and 436 struggle on and the G4 pick some up flawlessly.
Also the range is incredible. It can pick up sites that the Uniden scanners I have don't even know our transmitting! Ican hear the SAFE-T sites from the adjacent counties in all directions from me.
The only negative is you can only listen to one system at a time and can only monitor trunked or non-trunked at once. You can't mix systems or listen to multiple sites or listen to trunked and conventional at the same time.
K9KLC
Southwest, IL
Thanks. I do 99% listening to only one site and hopefully this will work out. Long Learning curve I suspect but, hopefully worth it.
KD9FAL
@kb9klc I have used a Unication g5 in VHF & 7/800mhz and it works great on the Madison county simulcast site. A G4 in 7/800 mhz should suffice instead of the G5. I got the G5 to use with MOSWIN VHF sites. Downside to the G5 is that VHF uses an internal antenna, but the 7/800 uses the external one.
K9KLC
Southwest, IL
Thanks, I found a pretty good deal on a G5 which I'm hoping to go and pick up tomorrow (Sunday) or Monday, assuming all pans out and I an hook up with the guy. He's "supposed" to put a starter program in there for me but I'm trying to figure out how to get him what I'd like in it not being familiar with the programming as far as talk groups and the site info. That's a shame on the internal antenna on the VHF side but I guess anything is better than nothing. I've used the 436 and 536 and was able to get a favorite list programmed into it but I have ZERO knowledge of how the G5 programs at this time. Again, thanks!
werinshades
Chicago , IL
I've been hearing 2/3-MI (Mary Ida)-x units today on ISP Troop 3-A with 7605x / 7606x RID's (2-MI-4, 2-MI-1,3-MI-2). Based on locations they're at, it would appear they're involved with IDPH Nursing Home licensing enforcement possibly? I never heard them before, or have seen RID's in that range.
Oak Brook is using 190xx RID's since Monday. Previously 191xx RID's for dispatch.
werinshades
Chicago , IL
I was able to narrow this down based on locations they were at and the radio ID's which fall under previously confirmed Illinois Attorney Generals Office (760xx series).
"The Illinois Attorney General’s Medicaid Fraud Control Unit (MFCU) investigates and prosecutes: Medicaid provider fraud, misappropriation of patient or resident funds, patient abuse and neglect in Medicaid facilities."
I will guess MI is the acronym for Medicaid Investigators?
KB9LMJ
Does anyone know what "OF" and "YOU" means in the trunking "fashion" column? It is not defined when you click on hyperlink.
WX9RLT
Top Dawg
That one place...
Few more Unit ID's for the Wiki
Oct 2024
Unit ID: 1007197
Unit Name: Sterling 1-75
Unit ID: 1007061
Unit Name: Sterling 1-59
Unit ID: 1107013
Unit Name: Sterling 1-58
Unit ID: 1007316
Unit Name: Sterling 1-66
Unit ID: 1107464
Unit Name: Sterling 1-79
Unit ID: 680506
Unit Name: Frank 1-45
Unit ID: 1007275
Unit Name: Sterling 1-72
Unit ID: 1007454
Unit Name: Sterling 1-78
Unit ID: 1005129
Unit Name: Sterling 1-20
Unit ID: 38537
Unit Name: Frank 1-36
Unit ID: 1106298
Unit Name: Frank 1-09
Dupage Cointy IL
werinshades
Chicago , IL
Troop 4 is affiliating on the DuPage site this morning and heard 4-MI-2 (4 Mary-Ida 2) with an RID 0f 433020. Looking at the Wiki since I don't have the 433xxx series documented on my list, this is a the block of RID's from the Illinois Attorney General's Office (Central-South). It would be safe to assume any MI (Mary-Ida) radio signatures in the middle are part of the Medicaid Investigations Unit of the Illinois Attorney Generals Office.
werinshades
Chicago , IL
RID update
RID 680520
UID 1-Frank-13
Oct 2024
Unit ID: 1007197
Unit ID: 1007061
Unit ID: 1107013
Unit ID: 1007316
Unit ID: 1107464
Unit ID: 680506
Unit ID: 1007275
Unit ID: 1007454
Unit ID: 1005129
Unit ID: 38537
Unit ID: 1106298
You can edit the WiKi:
werinshades
Chicago , IL
If I could, I would have.
But it would not allow me too.
It said that I was not allowed to edit the wiki, when I tried too.
Premium subscriber? If so, there's an edit feature available.
They are 1-xx, Sterling is the dispatch center.
WX9RLT
Top Dawg
That one place...
Yes, I am a premium subscriber.
And I still do not have the option to edit the wiki.
That is why I posted it here.
For an admin or another member can update it.
Figured it was Starcom related :)
Thank you for the info on the Sterling dispatch.
Learn something new everyday!
N9JIG
Sheriff
Moderator
Far NW Valley
Perhaps your subscription expired, you don't show a "Premium Subscriber" tag under your user name.
