Changed operations for site scan in ID scan hold mode
Now, when you hold on a talk group, the scanner will check all scanned sites for activity on that talk group. Previously, holding a talk group "stuck" the scanner on whatever site was being scanned at the moment the talk group was held. If you want to hold on the site, hold the site (independently of holding the channel).
Does the above apply to all system types, or specifically NXDN?
Now, you can issue MSM,600 (for example) and then spend the next 600 seconds (10 minutes) pushing programming to the scanner. When the timer expires, the scanner reboots back to serial mode.
Do you know what the max value is we can supply? If I do a copy/move of all my recordings off the scanner to my PC, it might take close to an hour. If I can issue MSM,3600 or even a bit longer than that, that would be ideal.
