Yes sometimes you have to just lock it on one system. So its working OK now?Think I got it. Only have trrop I site programmed. Ctrl channel only checked and 800 splinter for band plan. Any 996P2 owners having trouble try that.
No Band Plan for a P25 system.I wonder what the band plan is needed for if it's Control Channel only.
At least it works.
Yeah having the bandplan checked won't affect anything. It will just ignore it.Yes but after reading the scanner it changed the bandplan back. But its WORKING!!
I hope the leaves on the trees won't affect me but we will see ...I wonder what the band plan is needed for if it's Control Channel only.
At least it works.
My 996P2 has not stopped hearing CLMRN at all
Yes, It's an annual event - and complaint.I hope the leaves on the trees won't affect me but we will see ...
Ah yes good find. Sometimes less signal or maybe even a different spot is the trick.Well finally figured it out. The outside antenna I had connected to the radio works great for everything I'm listening to except for Troop I's control channel. Soooo I put a BNC "t" on back of the scanner. One side is the outside antenna, the other a little rubber duck. Now I hear both no problem.
Probably "attenuated out" the simulcast tower that was affecting his reception.Ah yes good find. Sometimes less signal or maybe even a different spot is the trick.
Hartford Fire Dispatch. It's in the DB, I put it in last night.TG - 16410 I've been seeing this all day. I'm on Troop H Site, 774.53125 .... what is this... anybody know?
Connecticut Land Mobile Radio Network (CLMRN) Trunking System, Statewide, Connecticut
Connecticut Land Mobile Radio Network (CLMRN) Trunking System Profilewww.radioreference.com
Last I heard, the 154.3100 on Mt Sinai will be back on once the new radio equipment is installed.hfd fire nothing @ all, not even on 154.31
Guess I’m gonna have 2 use my sds 💯,Hfd a good listen
