Harris XG-100P
IFRIED91
Arrive alive
NYC area
Both radios had the same identical mission plan loaded.
I’m surprised it still took it and didn’t give u a time stamp error feature not installed screen when u would turn to that channel
TDR-94
When you change the firmware the XG-100P will give a time stamp error in the faults menu.
IFRIED91
Arrive alive
NYC area
If you enable a feature The radio doesn’t have in rpm doesn’t it make that channel or system inoperable?
TDR-94
Usually, but it didn't with the other XG-100P without MDC-1200 in the feature menu. It just wouldn't show any hexadecimal data. It's quite possible that it was a result of an RPM and/or firmware bug.
TDR-94
It was either with RPM10 and XGP_R02A26 or RPM13 and I'm not sure which version of XGP firmware I would have had loaded at that time. When I had the MDC-1200 feature added, to that radio, it then worked fine.
IFRIED91
Arrive alive
NYC area
Hey let me ask… tho related to this thread.. feature 41 VHF Lo was supposed to be deleted from the Unity portables after a certain firmware version correct? Because… some reason I’m seeing still on a friends radio I’m reworking on
natedawg1604
Colorado
On the subject of Option codes, can someone explain why an M7300 like this one that presumably came from an ancient EDACS system, would have Option 47 TDMA, but no option 39? I thought TDMA was only used on Trunked systems with P25.
IFRIED91
Arrive alive
NYC area
Probably was from that wasted money failed NYS open sky system
IFRIED91
Arrive alive
NYC area
Or an ordering error...Opensky doesn't use TDMA (it's 4 slot, not 2 slot)
It was a NY State only firmware version that doesn’t even contain bootapp/burnapp/ECP…. Have you be extremely careful when looking to purchase one off eBay then u come across a deal too good to be true…
rjschilder
AES FTW
wow! I haven't personally run across those, but that sounds no good lol
IFRIED91
Arrive alive
NYC area
Yeah tbh with any any radio purchase I make off eBay 2nd hand PAYPAL PAYPAL PAYPAL…. Also I have the seller hook it up to a computer and send me videos…. No computer connection no deal
TDR-94
VHF LOW only applies to the XG-100M. The radio will just ignore option 41, since it doesn't support it.
IFRIED91
Arrive alive
NYC area
Yeah for Tx… but I heard some early Unity portables where able to RX only VHF-Lo… it really shortened battery life unfortunately
TDR-94
How far back in the development of the XG-100P was this? I have the original, separate, programming application for the XG-100P, before the radio even supported trunking, and I don't remember seeing the ability to program in any low band channels for Rx.
IFRIED91
Arrive alive
NYC area
Check out this one I have which is a Revision T I believe
TDR-94
The demo units have all the other 80 features that L3HARRIS had available at the time, but the XG-100P ignores any other features that it doesn't support. Like the mobile features and OpenSky.
What are the RF HW: and DIGITAL HW: version and the firmware in that particular radio?
Here's an example of one of the demo units that has all features enabled including WIDEBAND DISABLED, Option 58.
It is missing Option 41 though, interesting....
IFRIED91
Arrive alive
NYC area
Wow I never saw one that’s got a feature string so long haha.. votescan should be included by default i believe… when u select scan it will jump to the channel with the best reception…. I know this because I take mine to work and use it for traffic/road conditions on the NYS Thruway so I don’t have to listen to the news haha
Anyhow i ended up updating mine (not to the newest firmware skipping in between but gradually
TDR-94
Votescan has never worked on any of the ones I've seen without the feature enabled.
BTW. AES 5.01 is not meant for the XG-100P. That's for NON-FIPS capable. AES 4.01 is still listed as the latest for the XG-100P.
