ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
dave3825
Suffolk County NY
I have RSOIP running on my pc v 12.6. I am running the client on my laptop. My scanner does not show up. I have the server set to publish the ip. I have hit update a bunch of times and it's not there. If I manually enter the external ip and port, it connects fine. It just won't list itself in the client .
Any ideas?
mule1075
Washington Pennsylvania
Any ideas?
Having the same issue here.
Sent from my SM-S907VL using Tapatalk
ProScan
Software Provider
Ontario, Calif.
Any ideas?
What's the IP and Port?
ka5lug
Natchitoches, LA
Trial Reset?
I originally installed Proscan prior to making a decision about which scanner to purchase and due to procrastinating on my part, the trial expired before the scanner arrived. Are their any options available to reset the trial period?
Many thanks,
--Ron, KA5LUG
pinballwiz86
Missouri
ProScan is awesome, thanks.
I have a question. It won't broadcast the alpha tags on the web server. It just shows a play button on my cell phone. When I had the free trial it had a nice little screen replica of the radio display. How do I get that to work? Thanks!
ProScan
Software Provider
Ontario, Calif.
Does the Serve Audio Stream Password box contain a password? If yes then log in or check the Always Serve Stream Description check box. The 30 day trial/demo works exactly the same as the paid. You may have logged out or never logged in if using on a different device.
TonyN2KI
Washingtonville, NY
New to Proscan - what a really nice program. Just started to use the webserver portion of the software. Seems that the software crashes after an undetermined amount of time. End result is the software window that it is running in goes blank resulting in the scanner to be inaccessible remotely whether within the network or outside. End result is I restart the software to get back on line.
System is a Win 7 64bit Core i7 and version 12.6 ProScan. ANy suggestions? Thanks!
ProScan
Software Provider
Ontario, Calif.
Are you saying ProScan crashes when the Web Server is running? Just making sure.
Does the Windows Event Viewer sheds any light on the reason for the crash? Can you retest with the Web Server off to see if it crashes. I haven't seen the Web Server causing any crashes. I've seen a few causes of the Windows Update updating the video driver causing crashes but that's not related to the Web Server I believe.
TonyN2KI
Washingtonville, NY
Attached is a screen shot of what happens to ProScan. Where did you suggest to look for possible solutions?
TonyN2KI
Washingtonville, NY
Here is the data from the error field but I can not decipher it.
Problem signature:
Problem Event Name: BEX
Application Name: ProScan.exe
Application Version: 12.6.0.0
Application Timestamp: 59fd906c
Fault Module Name: KERNEL32.dll
Fault Module Version: 6.1.7601.23915
Fault Module Timestamp: 59b94aba
Exception Offset: 00000000
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 2bba
Additional Information 2: 2bba7f1a734eb5a6f84844ca89c1212a
Additional Information 3: ef31
Additional Information 4: ef31141e9d3bb2fb7abec2e3e8b369cf
ProScan
Software Provider
Ontario, Calif.
Problem signature:
Locale ID: 1033
It looks like something deep in the OS is doing it.
Try the following:
1. Try elevating ProScan to Admin. Rerun and see what happens. I doubt this will work but when I google searched this, It fixed it for one person that was getting this type of error with another program.
2. Retest without the Web Server running to confirm it's specific to the Web Server.
{edit} 3. Insure your Windows Updates are up to date.
Answer the following:
1. Does the Windows Event Viewer show any clues? The data you provided is not from the Windows Event Viewer.
2. What type of video adapter and driver manufacture & version?
TonyN2KI
Washingtonville, NY
Try the following:
--->Switched to "Run As Administrator"
--->WebServer is now off. But really that is the only way to tell if it crashes. If I can not access it via the web interface, I know then it crashed.
--->Windows is up to date
--->I do not see anything that appears in the Event Viewer, but then again I really do not know where to
look for any data within the Event Viewer.
--->Here is my graphics information:
Intel HD Graphics 3000
Manufacturer Intel
Model HD Graphics 3000
Device ID 8086-0112
Revision A
Subvendor ASRock (1849)
Current Performance Level Level 0
Current GPU Clock 847 MHz
Technology 32 nm
Driver version 9.17.10.4229
ProScan
Software Provider
Ontario, Calif.
Manufacturer Intel
Device ID 8086-0112
Revision A
Technology 32 nm
Can you answer the questions that I asked before and same with the things to try.
