ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ka1air
Connect to 996P2
Downloaded the new version of Proscan 12.8 and now unable to connect to scanner.
get message "in use by interface"
I set it back to none.
retry
\Then get message "available"
Highlight available then clicked set.
Nothing happens.
ka1air
Connect to 996P2
Tried it a couple more times and it eventually connected.
I didn't do anything different except kept retrying.
So, i guess i am ok now
KA1AIR
ProScan
Software Provider
Ontario, Calif.
retry
Nothing happens.
No changes in that area so I don't believe problem related to upgrading to ver. 12.8.
ProScan
Software Provider
Ontario, Calif.
Problem with my site. On live Chat with HostGator now.
Thank you for using Live Chat. My name is Dominic and I will be your Web Advisor for today. Please hold on while I review your concern.
It appears that you are having issues with your SSL. Don't worry, let me do my best and assist you with it. May I have your domain name, please?
Thank you for that! I will be reviewing the Invoice that you have provided as well as the SSL installation.
I seem to have issues with it. Please hold on, don't worry as I will be getting this resolved for you.
For an update, still working on it.
mlapaglia
I have radiofeed running on a dedicated server that I remote desktop into. When I disconnect a remote desktop session and then reconnect, I can see the windows audio bar for the microphone go up and down (it's seeing the audio coming in from the scanner) but the audio bar in radiofeed doesn't move, and no audio is transmitted to the server.
curtisdevault
Bozeman, MT
I think this is caused by the way Microsoft's RDP works. I haven't figured out how to get RDP to stop messing with the audio device settings. Now I only use TeamViewer or Splashtop to access my streaming server. Neither of them break the audio settings.
mlapaglia
Stupid windows! Another alternative is starting a VM with windows running on the server. I'll see how that works.
ProScan
Software Provider
Ontario, Calif.
"I can see the windows audio bar for the microphone go up and down"
Are you referring to the Windows Mixer Mic level meter or the RadioFeed Source Client meter?
Does RadioFeed meter shows audio when not using the Remote Desktop?
In RadioFeed, make sure you have the correct Input Sound Device selected and the level control is at 100%.
mlapaglia
The windows mixer mic level goes up and down.
Once I disconnect a rdp session no audio shows up in radiofeed until i restart the application, then it starts working again.
Yep, levels are at 100%, the app works fine until i disconnect from the rdp.
NYRHKY94
Brunswick County, NC
A Curtis has noted, you may be running into a native issue with RDP. I've experienced the same thing over the years when using RDP to access my feeds remotely. I too have switched over to the free version of TeamViewer to avoid the issue. I previously used LogMeIn until they priced me out of the market. There are quite a few posts regarding the RDP audio issue in various MS forums, with several of them pointing to a Group Policy setting for enabling audio redirection during an RDP session. Haven't tried that, but may be worth looking into if RDP is your preferred remote access tool.
jeatock
090-45-50 W, 39-43-22 N
Windows remote desktop and remote reboot
RDP works fine. I run it on multiple machines...
BUT!
Edit the RDP settings BEFORE you connect the RDP session, and make sure "Audio Playback" is set to "Play on remote PC".
If you use the default "Play on this PC" Windows will route the audio input to your remote session and away from your streaming program. Windows does not 'return' it to normal when the RDP session is closed.
Finding those advanced settings depends on the Windows OS version. Trust me, it's there for all of them.
I also put a file in my c:\ directory called reboot.bat. Open NotePad and create a .bat file with the following: "shutdown /f /r /t 10" (shutdown, force programs to close, reboot, and wait 10 seconds to shut down). Save the file (make sure it has the .bat extension - not .txt) and put a shortcut on the desktop. That makes rebooting remotely much simpler, especially if you forget and pull audio away from the remote machine. I have found that a remote clean boot is the best way to return things to normal.
mlapaglia
Yep I have the settings correctly adjusted. The audio works while the remote connection is running, but it stops working once i end the session.
NCIC105
Somewhere over Georgia
For some reason every night around 2am my scanner disconnects from the Internet....This started with the most recent upgrade of Proscan.....
When I looked at my burg alarm system it does not lose connection during this time...They are on the same router...
Windows 10 PC, Uniden BCD996XT, ASUS RT-AC68U router...
jonwienke
More Info Coming Soon!
VA
Reserve IP addresses for your scanner and the computer running ProScan in your router settings. That fixes the problem 90+% of the time.
mlapaglia
Interesting finding today:
When I click on the "Web Server" tab that I started using yesterday that feature still works when the RDP session is started and stopped. I go back to the "Source Client" tab and the volume bar isn't working.
