ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
jonwienke
More Info Coming Soon!
VA
Thanks for the help! No telling how long it would have taken me to figure this out since I did not know about the "scanner specific" tab. I have been super busy with things other than scanning so I have missed a lot of details in the last couple of weeks.
By the way I am using your 2nd Profile.cfg that you posted.
You're welcome. Glad you found my profile useful.
ProScan
Software Provider
Ontario, Calif.
Double-check which profile ProScan is looking at, and open the selected profile in Sentinel to verify that it has the colors you want. If the colors shown in ProScan are the same as those in the selected profile, then there is no bug. You need to go into Sentinel and fix the colors in the profile. When you select a profile, ProScan will use it, even if the selected profile has an unreadable color palette.
Great customer support! and perfect advise. Thanks.
ProScan
Software Provider
Ontario, Calif.
Clicking the mute button blacks out the bottom half of the SDS100 scanner display for about 10 seconds, both muting and unmuting. Doesn't bork anything on the 536 display. Appears to hang the display refresh for some reason.
Can't duplicate. What's the View type?
jonwienke
VA
Detailed and simple trunk, but only while a site hold is active. It also happens when I click the scroll knob to adjust the volume/squelch during a site hold. It appears that site hold borks the volume/squelch bargraph display, making the bottom half of the display go blank.
ProScan
Software Provider
Ontario, Calif.
I do see one minor bug though. If I select "Scanner Only" the display looks great ... except that there is an extra copy of the current frequency in blue text inside a blue box about halfway down the virtual display. It looks like the frequency field from the 436HP virtual display. If I pick any of the other view options it goes away.
Both are fixed.
Unzip and copy the exe file over the original. http://proscan.org/ProScan.zip
ProScan
Software Provider
Ontario, Calif.
mancow
N.E. Kansas
In the SDS100 library editor the Update Text Tags window does not open fully and cuts off the right side.
ProScan
Software Provider
Ontario, Calif.
A few more cosmetic problems are fixed with the SDS100 support in ver.14.0
  • Permanent Avoid wasn't showing.
  • Display Soft Keys when clicked now will show a slightly lighter color for visual feedback.
  • Removed the Hold button when the View type is set to Display Only as the display soft keys will hold.
Unzip and copy the exe file over the original. https://proscan.org/ProScan.zip
timkilbride
Linn Co Iowa
I imported BENTON CO from a 996xt file. Public Safety through Vinton departments show up at TGIDs(these were in the original file I imported.. I added departments Keystone through Van Horne. Those show up as Freqs. I am unable to move the departments into alphabetical order. The only work around I have found is to copy and paste from one of the departments from the original import. Then modify everything in the new copied department. Is this a bug?
Thanks,
Tim
timkilbride
Linn Co Iowa
Thanks,
Tim
Furthermore, I wrote what I had to the scanner(with Proscan) and got a error saying "over limit". I used Sentinel to read the scanner and everything I imported was missing. The only usable systems were the ones I made from scratch.
Tim
ProScan
Software Provider
Ontario, Calif.
Thanks,
Tim
What type of system in the 996XT file? What's the scanner type set at?
ProScan
Software Provider
Ontario, Calif.
Thanks,
Tim
I did a test just now. All systems types in a 996XT file imported to the SDS100 Favorites fine including talk groups and site frequencies. I'm able to drag and drop nodes just fine. I see the screenshot you provided shows the system as conv. I would try again importing the 996XT file and watch at what point in the process it changes to conventional.
timkilbride
Linn Co Iowa
I put up a screenshot of what the screen looks like after I select the 9996xt file I want to import. The visible systems are indeed conventional systems, but the groups are showing TGID's.
Tim
