ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
W4KRR
Coconut Creek
ProScan 14.0 doesn't detect my SDS100. I can read and write to the scanner from Uniden Sentinel, but ProScan doesn't show any COM ports available (Windows 10).
RF23
You might also try turning off your SDS100 then turn it back on to allow it to reconnect to windows.
Then start Proscan.
It worked for me on my very first time using Proscan after it had been updated for the
SDS100.
W4KRR
Coconut Creek
It would seem that Serial Port mode is used for recording and logging. But USB mass storage mode is needed for reading & writing to the scanner. Is this correct? I don't remember having to use Serial Port mode for other model scanners.
sallen07
Rochester, NY
Yes, and that's how it works with the BCD436HP and BCD536HP too. The other scanners supported by ProScan are not SD card based, so no need for "mass storage mode"; their only mode is "serial mode" which is why you never had to pick that before.
RF23
SDS100 - Record icon disappearing
When locked on a System containing only conventional analog frequencies if I turn on the “Record” function every time a channel becomes active the “REC” icon disappears from the display in Proscan only.
On the SDS100 the “REC” icon behaves normally with the background changing color at each active transmission but always present.
Recordings are being made on the SDS100.
CP285
Sterling Heights
Good afternoon,
was wondering how I can get proscan from my desk top to my laptop? I've only used proscan on my desk top, bought new laptop and want to transfer it over or can I just download it from the sight? Cant find original network key.
Thank you.
Charles
ProScan
Software Provider
Ontario, Calif.
Good afternoon,
Thank you.
Charles
Download and install on the laptop. I send out lost keys on Mondays by email only.
{edit} Or you can copy the folder on the desktop if you want to retain the config and logging data.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 14.1
What's New In Version 14.1
Fixed - SDS100 display cosmetic issues.
Fixed - Favorites Editor(BCDx36HP, SDS100) wasn't importing ProScan Conventional systems correctly.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, & SDS100 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
RF23
Does the URL that you are using from Bob's site read 14.1?
I did not have any trouble getting it and it fixes the problem I mentioned too that was in 14.0.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
He's likely not using a URL, but instead letting the software download it automatically. I'm having the same issue; the automatic update check is downloading 14_0 repeatedly.
Downloading it manually from the website would solve the problem.
ProScan
Software Provider
Ontario, Calif.
Yeh that's it. It's fixed now. Thanks.
druhe
Southwest Pa
Version 14.1 error
Downloaded via auto update and direct from website, after installation I receive an error message and the program will not open. Had to uninstall and go back to version 12.13.
