ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
CanesFan95
Was Homeboys-Scanna
Banned
FL
I don't have the registration key from back when I bought the software. Would you know if there's a way to re-obtain the key?
kruser
Well Known Member
W St Louis Cnty, MO
Understood, will do thanks.
Yep, I've never needed to ask Bob for a key resend but I hear he has no problems doing it.
One thing I've always done is either copy the text from registration emails that contain key info or print or convert it to a PDF and then save that in a folder named something like registration info or something you can find easily if ever needed.
That's saved my bacon a few times!
It's good free insurance other than the short time it takes to do. Plus, you don't need to search emails for the info.
Good luck
Remington12G
GØT AES?
Need help with my ProScan software, I cant find my key for activation, I want to add the software to my second pc but cant find my key.
ProScan
Software Provider
Ontario, Calif.
Check your Spam folder. If the Spam folder was cleared then it may of moved to your Trash folder. If you still can't find it then email me. I usually send out lost keys on Mondays by close of business.
zuzuski
New London, CT
I can connect and put the scanner into "Mass Storage" mode and manipulate my database just fine.
When I reboot the scanner and choose serial mode, I cannot get PROSCAN to start at all. Just an empty proscan screen.. What simple step am I missing to start control and logging?
ProScan
Software Provider
Ontario, Calif.
That's good. It proves the cable is good.
Doesn't start or blank virtual screen? My guess is blank virtual screen.
I bet you don't have the serial driver installed. See the section "Windows Serial Drivers" in this link. The driver will work for BCDx36HP and SDSx00 scanners.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 15.5 Just Released.
  • Added - BCDx36HP & SDSx00 scanners - Selectable Favorites when writing to the scanner.
  • Added - BCDx36HP & SDSx00 scanners - Web Server button on Web Page to reboot BCDx36HP and SDSx00 scanners when logged in as Super User.
  • Fixed - BCDx36HP & SDSx00 scanners - The NAC's wasn't importing correctly from the RRDB when importing conventional P25 frequencies.
  • Fixed - BCDx36HP & SDSx00 scanners - Favorites Editor - Not all system parameters was showing in the Systems Options grid.
  • Fixed - Logging To "History Log.txt" File wasn't logging start time & duration correctly.
  • Fixed - RSOIP Published Servers list was missing a few states & provinces.
  • Fixed - Recorder Lookup Flag From Database wasn't working on conventional systems on DMA type scanners.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, SDS100, SDS200, SDS100E, SDS200E, UBCD3600XLT, & USDS100 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
cg
Connecticut
Working for me. What specifically is not working? I get it to log calls (P25 trunking), show aliases from the UID Lookup File, and sort by clicking on the headings.
Did you check your Options/Loggings settings to verify it was enabled?
chris
