ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
n8jsw
Ohio
Is there a way under record with a SDS200 to see what time slot a talk group is on scanning a Phase II system ?
CanesFan95
Was Homeboys-Scanna
Banned
FL
Sorry if this has already been asked (I haven't read this whole thread), but I'm getting an error when I try to download the version 16.1 update (screenshot):
Has anyone else had this happen? Thanks.
GTR8000
NY/NJ Database Guy
BEE00
Or you could just download it directly from the website? :unsure:
ProScan
Software Provider
Ontario, Calif.
It's fixed. It will be in the next release. In the meantime, download directly from the proscan.org web site.
signguy10
Saint Paul
Just curious. I am running the trial version of the software with two sessions of ProScan on two computers. I know it says the key will activate the software on two computers, does that included multiple sessions as well?
regression
Germantown, TN
Good afternoon. I recently purchased ProScan and am looking for an option to display talk group names instead of IDs. This is in the screen showing recent hits (below the picture of the scanner). I am using a BCD436HP. Here is the section I would like to show the text instead of ID's. Is this possible?
82214
kruser
Well Known Member
W St Louis Cnty, MO
That info will be shown on ProScan's main log screen under the "System/Site - Department - Channel" column providing you did not remove that column. You also need the TG name entered into the scanner so ProScan will pull the name when the TG is active.
I can't get the image to resize so not sure you will be able to see it.
regression
Germantown, TN
Oh wow, I am embarrassed to say that column was on my screen and I completely missed it! Too much staying at home is getting to me!
regression
Germantown, TN
Good evening, I have another question about ProScan. I am using it to program a BCD436HP. Recently I decided to redo a bunch of my favorites lists. I created new lists, moved systems from various favorites lists to consolidate them, etc. I ended up deleting some favorites lists in the editor in ProScan. Then, I wrote to the radio. I then discovered the favorites lists that I deleted in ProScan still exist in the scanner. Using Sentinel, I would have picked "erase favorites list on scanner" before writing to the scanner. Is there an equivalent option in ProScan?
In this case I remembered which favorites list I deleted, so I went into the scanner to delete them manually.
GeekNJ
Testing out ProScan with a generous extension by Bob. I have gotten a message like this twice so far and wondering if there's an adjustment the top level directories where you can place the recorder files so I can reduce the overall path name/length? I didn't locate anything when reviewing the options tabs in the app beyond the final date/system. The only match I got on this dialog title was in the current doc/manual where it appears added in 16.0 but I don't see a way to adjust for a shorter path.
Edit: A followup about the new dialog, as it is a modal window, when displayed, there are no further recordings captured until the message/dialog is dismissed. It seemed to occur last night at 10pm and I noticed this morning at 7am. I'm not sure if that was intended vs alerted a single recording might not have been created.
Thanks & stay safe.
82576
