ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
What is the usual ProScan release schedule?
Usually a month or two or maybe three. If a new feature then it may be longer. It depends on if a major bug, or a Win Update broke something, or a lot of fixes, changes, or additions. Also bug reports that comes in initially via email, I'll send out test files until fixed.
Firebuff66
CT
On My 3 996P2s the alert light is solid yellow and 1 996XT is blue and 1 is green....It will flash red as I have set it but I can't find a way to change the solid light color (That it didn't have untill19.0) IMG_0803.JPG
ProScan
Software Provider
Ontario, Calif.
ProScan Version 19.1 Just Released!
  • Fixed - When the option "Select Activity Display Back Color" is set to "Alert Light", The display back color may not appear correctly.
  • Fixed - Alert light was always on, on the BCD996P2, BCD996XT, & BCT15X scanners.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
FrensicPic
Los Angeles
Installed Version 19.1 (upgrade from 19.0) this morning. After uploading the database to my 996P2, ALL systems and groups were ON. This is contrary to what is indicated on the Quick Keys/Search Keys tab. Same thing happened to my 325P2. Any way to roll back to 19.0?
Anyone else?
John
smason
Alberta Canada, Eh!
This happened to me once on 19.0 Haven't uploaded again since then.
kruser
Well Known Member
W St Louis Cnty, MO
Anyone else?
John
Look at the new Quick Key options in the Upload dialog box under Configuration. The radio button to turn them all on at Upload is likely checked.
This feature was noted in the release notes for 19.0 that it was a new feature added for DMA models.
FrensicPic
Los Angeles
Thanks for pointing that out however, "Turn On All ... " is unchecked as is the other two configuration options.
ProScan
Software Provider
Ontario, Calif.
Anyone else?
John
No changes between 19.1 and 19.0 in this area.
