ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
so why does this happen like that on the software where some systems are turned off but the system quicks and group keys are on in the scanner?
In Proscan you need to first "Read from scanner" the groups that are enabled on scanner so Proscan can recognize that they should be enabled in the app
MichaelC34
Boston, MA
what you mean read from Scanner? So in other words if its off in the proscan app then i wont be able to listen to it on the scanner? Which is kind of odd cuz i did hear some of those groups that are listed off in the software
ProScan
Software Provider
Ontario, Calif.
ProScan Version 19.0 Just Released!
  • Added - The History logging grid now logs the Service Type when using BCDx36HP and SDSx00 scanners.
  • Added - DMA Database - Upload SQK/GQK options.
  • Added - Favorites Editor - Write to scanner option "Turn On All System, Dept., & Site Quick Keys In The Scanner".
  • Fixed - History logging would show multiple entries for the same frequencies or talk groups.
  • Fixed - Alert Light on the virtual display wasn't working correctly on the SDSx00, and P2 scanners.
  • Fixed - DMA Database - Using CTRL-C keys for copying nodes was causing the next node to be selected.
  • Changed - DMA Database - The TGID Lockout grid now is read only and the grid data is from scanner only.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
R0am3r
Salt Water Conch
Oneida County, NY
I have a laptop that is failing and frequently crashes with a blue screen. I have a licensed copy of ProScan on the laptop and I want to move it to my new laptop. Assuming I can keep the old laptop running long enough, I will uninstall on the old laptop and then install ProScan on the new laptop. If possible, I would also like to manually copy the user files from the old laptop to my new laptop. Two questions:
1. Are the ProScan user files housed in the VirtualStore folder as discussed in Post #7201 above? Yah, I am trying to avoid remembering how to configure the software to talk to my Uniden SDS200 scanner.
2. If I can't uninstall the software properly on the old laptop to free up the license, is there a workaround? Fingers crossed that the old laptop stays alive long enough to uninstall ProScan and free up the license.
fxdscon
¯\_(ツ)_/¯
To free up the license from the old computer.....
When Proscan is running, from the top menu bar just click on "Tools", then "Remove Activation". Then just use your registration keys on the new computer.
ProScan
Software Provider
Ontario, Calif.
VirtualStore folder only if ProScan is installed in the Program Files(x86) folder AND running a 64 bit OS AND not running ProScan in admin mode. An easy way to get to the correct folder is by going to the Test & Extra tab then click on the Win File Explorer button. Just copy all files to the new location. You may want to edit the config. ProScan.cfg file and the lines containing paths (or locations) then start ProScan.
WVHillbilly
Over yonder
Installed the 19.0 upgrade this morning and now the alert light on the screen display does not display any color. Shows a gray background.
BCD996P2.
