ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Chris0516
Pittsboro, North Carolina
Are you talking about all the fields listed on that tab in your screenshot? The "v" is always there, that's an indicator showing there are drop-down selections available. I see borders around the fields in your screenshot. Doesn't look any different from the 996P2 database I have open in ProScan 19 on my PC right now.
Yes, The fields. The background on the fields was a different color than the rest of the screen. It helped make them more distinguishable.
ProScan
Software Provider
Ontario, Calif.
That's it. Thanks.
It was previously configured with borders, instead of the 'v'. I want to put it back that way.
I think that's more to do with Win 11 changing the styles.
flanker86
Hello,
I have a configuration with Intel NUC and UBCD3600XLT scanner (Win 10 and latest Proscan, but earlier versions also had the same issue). I have a problem to reconnect to the scanner after a Windows upgrade reboot or grid power failure (as UBCD3600XLT is on battery). Every time this happens I have to manually turn off and on again the scanner for Proscan to see it correctly. I have tried reseting the port to 0, refreshing the ports, turning off and on the port via device manager, but no success. Any ideas how to solve this issue?
Chris0516
Hello,
I may be missing something. But every time I have to reboot the PC. I have to:
1. Disconnect the USB cable from the scanner
2. Power cycle the scanner
3. Re-connect the USB cable
4. Start Proscan
There is no need to change the port for this.
ProScan
Software Provider
Ontario, Calif.
4. Start Proscan
Try just power cycling the scanner and not disconnect and reconnect the USB cable then start ProScan.
JeffHiggins
Toronto, Ontario, Canada
For anyone that wants to use ProScan behind a Traefik reverse proxy I've created a file provider config that will rewrite the references to the local address and port. You can find it here with explanations of what it is doing. It's not 100% though and still has some issues, that is also outlined in the snippet. (this post is likely mainly going to be helpful for people that come looking in the future)
I have also sent an email to Bob about what changes could be made to make ProScan reverse proxy (or even just port forward) friendly so hopefully this won't be needed at all in the future 🤞
I've also created my own web page that displays multiple scanners on the same page making it easier for me to pull them up quickly from my phone in one place, and monitor more than one channel at once.
This taps into ProScan's web socket to communicate with the scanners so it is still necessary to have the web server running, but it doesn't need to be exposed and you can proxy the web socket. It uses PHP to load the scanner list from a files so you can easily add or remove scanners without modifying the page. The source code for this is here if you would like to implement it yourself. There is lots of things I would still like to add to the page, check out the issue list to see what I have planned.
flanker86
4. Start Proscan
OK, but I want to run it fully remotely. From your responses I understand that it cannot be reconnected without physically turning it off and on again?
ProScan
Software Provider
Ontario, Calif.
That sounds like the infamous driver to scanner communications problem that happens on the 996P2 and later scanners. The problem is when ProScan or any software is communicating with the scanner and the computer reboots then the scanner stops responding to polls. The only way to restore communications is by reinserting the USB cable or power cycling the scanner. If you're using the Uniden driver, see if the Microsoft driver works better.
kruser
Well Known Member
W St Louis Cnty, MO
I don't have a link. It was installed automatically on Win 11. Not sure about Win 10. I use it with the 996P2 and SDS200.
Hi Bob,
Does the Microsoft driver seem to help with the issue being discussed?
I'm used to power cycling the trouble models and also built some remote power switches accessed via TCP/IP if needed for those same models.
Anyway, just curious if the Microsoft driver installed with your Win 11 install seemed to help or not.
Thanks Bob
ProScan
Software Provider
Ontario, Calif.
Hi Bob,
Thanks Bob
Can you try it and find out out. I don't want to reboot my computer now as I'm in the middle of a coding session. Thanks.
// I think I tested that a few months ago using the MS driver and the scanner comms came back up on its own but not certain.
kruser
Well Known Member
W St Louis Cnty, MO
No, cannot test. I'm not running ProScan on anything higher than Win 7.
It was just a curiosity thing! Don't stop your coding session to answer my question! Someone else may test and reply.
Chris0516
Could you provide a link to a correct Microsoft driver, please?
Flanker, Same here. Except w/ Win 10, I used a Uniden USB driver, until I upgraded to Win 11.
