ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
N1SQB
Somewhere On Earth
It SHOULD stop being controllable by ProScan when in mass storage mode...that's normal! Unplug the USB, reconnect the USB, hit the button on the scanner to enter Mass Storage Mode, read/write to your heart's content.
have you read my posts comlpletely? I AM doing that. It is in MASS STORAGE mode that the scanner stops communicating and the program will not read from/write to the scanner....
eddie8965
Hamilton Co. Illinois
Try 19.7.1 (from the website, not in app update) and see if that fixes it.
Yes sir,That solved my problem,thanks !!
ProScan
Software Provider
Ontario, Calif.
Does the scanner display show "USB Mass Storage"? What type of scanner? Are you seeing an error message? Didn't you swap out cables before when you thought that had something to do with the Sentinel server down? If so, can you put back in the original cable.
03msc
RF is RF
The Natural State
So the screen on the scanner says it's in mass storage mode but it won't read/write?
Sounds like a cable issue. Remember you can always read/write direct to the SD card with the card inserted into a simple card reader connected to the computer. That's how I update my mobile scanner(s) 99% of the time...no cable needed.
But, yes, cable should work as well. If you've changed cables or something then switch back.
I can assure you that no one is trying to be difficutl but, to be frank, some of your posts have been confusing and led us (or at least me) to believe you were trying to do it backwards (i.e. read/write while in serial mode instead of MSM). Sorry if I/we have misunderstood. Could be that your question would be better in the Uniden Technical subforum, however, too.
ProScan
Software Provider
Ontario, Calif.
N1SQB, Are you trying to get the scanner display on your computer or read/write the favorites from/to your computer? You can do both but not at the same time. When the scanner is in Mass Storage mode (non Serial Port mode) then you should be able to read/write the favorites to/from your scanner. When the scanner is in Serial Port mode (non Mass Storage mode) then you should be able to get the scanner display on your computer.
If you can answer my questions, that would be great so we can help and we we can take it one step at a time.
What type of scanner are you using?
Are you trying to get the scanner display on your computer or read/write the favorites from/to your scanner?
03msc
RF is RF
The Natural State
This is why it's difficult to give specific help...this sentence of yours creates the reaction from me of "good, that's what happens when in MSM...you want it to stop showing on the screen/being controllable by ProScan when in MSM!"
But I'm not there with you so I don't know exactly what's happening. It sounds like you're switching to MSM and then when it disappears from the screen on ProScan you think it isn't working...yet, it is. Then you Scanner Write and the window pops up and shows the scanner selected.
If it is not doing this then it's likely a connection issue and unrelated to ProScan itself. If it was a ProScan issue then all of us, or at least many others, would be having the same issue. We can still try to help, just need more details.
Please follow-up with an answer to the questions ProScan asked above and give more details...as what I quoted still doesn't sound like an issue unless you mean something different than what was said (i.e. I don't know what to read between the lines). I understand it's sometimes difficult to convey what's happening on the screen or on the scanner into words in a post but give it a try. Step by step or something.
N1SQB
Somewhere On Earth
I understand how the software works. I was trying to read from then later write to the scanner. I think I have it solved though. I cleared all the USB ports, then plugged the scanner into a different USB port after moving some other items around, and now it is working. Not sure if it was a port issue or what but it is working.
ProScan
Software Provider
Ontario, Calif.
Thanks for the update.
N1SQB
Somewhere On Earth
Thank you for your help. I have one question, maybe it was me, but I thought in past versions of the software, the virtual screen mimicked the exact colors that the scanner has, in this case, the SDS200. I'm asking because when it boots up, the software shows one solid color on the display, not a copy of what the scanner is set to. Is this supposed to happen? Here is what I mean. ( see pics) I know the color is changeable, that is not the issue. It's the screen being one solid color instead of the colors on the scanner screen. No big deal but I am curious if there is a reason for this.
ProScan
Software Provider
Ontario, Calif.
That's normal when the scanner boots up (or is in menu mode) because the Sentinel profile colors only defines "Simple Conventional", "Simple Trunk, Detail Conventional", etc. modes and not boot or menu colors. Never in past versions did it do that.
{edit} If the scanner is in a mode that is not defines in the Sentinel profile then the colors will come from the Options - General - "Display Fore Color" & "Display Back Color"
N1SQB
Somewhere On Earth
That's normal when the scanner boots up (or is in menu mode) because the Sentinel profile colors only defines "Simple Conventional", "Simple Trunk, Detail Conventional", etc. modes and not boot or menu colors. Not past versions. No changes in this area in the longest time.
oh ok. So there's no way then to boot up in detailed trunk mode which is what my screen is set to. Ok got it. Maybe something to think about for future updates? It wold be nice.
ProScan
Software Provider
Ontario, Calif.
I see now. On the instance that is showing one color, go to the Options -> Scanner Specific tab then click the "Sentinel profile.cfg File Location" button then choose the location of the Sentinel profile using, then click the OK button.
ProScan
Software Provider
Ontario, Calif.
Folks,
I'm trying to decide on the next major feature, and suggestions to do next. I have an email list but I think I want to start fresh so I'm going to delete all the existing suggestions I have.
If you have a suggestion, post it here or email me in a new thread. Please keep it to the point and make it so I can understand it easily. I may do the easier ones first or the ones that will benefit more users, and of course, the ones that I like. I probably am not going to respond to every suggestion. Thanks
N1SQB
Somewhere On Earth
Now i'm cookin with gas....LOL Thank you very much...The virtual screen matches exactly to the scanner's screen. :cool:
ProScan
Software Provider
Ontario, Calif.
Just a FYI, since doing the last update, proscan crashes every couple days now. Before the last update, was running fine for months without issues. Something change in new update?
Not that I'm aware of. I'll keep an eye out for others having same problem.
Can you revert back to 19.6 and see if this does it too.
ProScan
Software Provider
Ontario, Calif.
I will mess with it more this week and see before reverting back. Win10 sucks and bet that’s the issue. Never had issues with win7. I’ll let you know.
Personally I think Win 10 and Win 11 are the most stable versions yet. I've seen problems in the past with the graphics deep down in the OS causing problems with video drivers but I haven't seen that recently.
