ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Nchpiboy
Hayesville, NC
Getting this pop up after 19.7 install. Occurs during import from RR.
Any ideas on how to fix?
Update: Reinstalled 19.6 and error does not occur.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 19.8 Just Released!
  • Added - Display Only (Borderless) changed to Display Only (Sizable). Right click the display when in Display Only mode for the options.
  • Added - Modify Uniden Database utility - Added a "Check Found Channels" option to the Find & Replace tab.
  • Added - Startup option - Minimize to Taskbar or Notification Area.
  • Added - BCD536HP & SDS200 Ethernet audio - Option to log to file when loss of audio is detected and scanner auto restarts.
  • Changed - History, UID, & Recorder logging grids - Separated the group/department & channel columns from the system/site column.
  • Changed - Changed the option "Restart Scanner Upon Loss of Ethernet Audio After 5 Minutes" to a user selectable 1 to 10 minutes.
ProScan Website
The Display Only (Sizable) view option is the latest addition and one of the most requested items.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
freqseeker
Puget Sound WA.
I finally had time to update to 19.7, went to website and noticed 19.8 was available. Installed 19.8 and then received this forum notification that 19.8 was available.
Perfect timing! Now to check out the new features. Thanks Bob.
WX9RLT
Top Dawg
That one place...
ProScan Website
Made in the USA
Thank you
mr10pt
Lowell, IN
Can not find the option to "restart scanner upon loss".....
Can someone point me in the right direction please.
sds200 if it matters
