ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Actually 10 is way more stable and reliable than 7 ever was. This is a generally accepted statement in IT circles everywhere.
Thank you. I'll add that on Win 11, a problem I have seen, not really a Win 11 problem but rather a certain USB Serial Port driver will show in the Device manager something to the effect "Not compatible with the OS". Also somewhere along the line of updating Win 10 or Win 11, the microphone privacy setting will turn off on all apps.
bearcatrp
Land of 10,000 taxes
Its working again. Did a windows update last week and for some reason it kicked the computer off line. Didn't realize it until this morning messing around with it. Never use it to go on the web.
jasferriter
I have Proscan working through my scanner on the computer, but am having trouble finding out how to import a feed from Broadcastify. I assume it can be done. Thanks
03msc
RF is RF
The Natural State
What do you mean "import a feed from Broadcastify"? Broadcastify is a service where scanners are streamed to. Is that your goal, to stream your scanner up to Broadcastify?
ProScan
Software Provider
Ontario, Calif.
What if I wanted to just use the editor,is there a setting that would prevent the web client from always popping up ?
Go into the Startup options and uncheck the items you don't want to start when ProScan starts.
{edit} I'm not sure what you mean by "web client" Can you provide a screenshot if the startup options doesn't fix it.
ProScan
Software Provider
Ontario, Calif.
Bob, Strange situation here-
Recently, On the menu. The 'Database' link was moved to where it is now next to 'History Logging'. Is this because of the update, or something else?
Can you drag the Database column to where you want. It's probably because switching scanner types from a BCDx36HP or SDSx00 that doesn't have a Database tab (Favorites but that is accessed a different way).
