ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
VK3YMML
VK3VSN / VicScan Forum Owner
Melbourne, Victoria
Is there an "official" limit to how many scanners you an have working with Pro-Scan or is this only limited by the computer and the amount of USB devices connected.
At this stage I only have 7 scanners (
UBCD 436-PT, UBCD 436-PT, UBCD 536-PT, UBCD 996P2, UBCD 996XT, UBCD325P2 and USDS100
ProScan
Software Provider
Ontario, Calif.
No limits in ProScan.
KC2NNS
Freehold, NJ
Good morning.
Not sure if I'm the only one. Seeing strange behavior with the recordings. Everything works fine for several days/weeks but then suddenly the program starts saving the recordings as empty files with no audio. They're roughly 500 bytes. I opened a few in a text editor and they seem to have the metadata but no audio. A reboot of the machine fixes the issue, but it returns after a while.
-Jon
Quickcall
Director of Saltiness
Central New York
Good morning.
-Jon
Came here to say the same thing. Did not change with the update.
ProScan
Software Provider
Ontario, Calif.
Good morning.
-Jon
Next time it happens, go to the Win Mixer and see if the audio meter moves. That won't apply if using the ethernet audio on the BCD536HP and SDS200.
ProScan
Software Provider
Ontario, Calif.
Folks, I need several good testers. Mainly if using the following.
  • RRDB Differences function
  • Database 'Note' column. Channel level.
  • Database 'Record'(1) column. System and channel level.
The above works with the DMA, BCDx36HP, & SDSx00 scanners
Test version 23.5.0.0
Unzip and copy the files over the originals. Stop ProScan 1st.
The RRDB Differences function should be much more reliable now. The 'RRDB Import.txt' file was causing problems with the RRDB indexes getting lost or changed. The purpose of this file was to store the RRDB system, group, and site indexes. Now, the indexes are stored in the ProScan database.
After opening a database in ver. 23.5 and above, the 'RRDB Import.txt' file is read and the indexes are transferred to the ProScan database and then the 'RRDB Import.txt' file is of no use.
The database Note and Record(1) data should be much more reliable now in retaining the data after a download (or read from scanner). Unfortunately, none of the scanners support 'user data' that can be uploaded to the scanner and downloaded. The data will be lost so a helper file is needed. 'ULDLData.txt' stores the data before an upload and before a download and then will transfer the data back to the ProScan database after a download.
(1) Record on the non-record supported scanners (DMA portable scanners).
Dhouse900
Hi, I just did a fresh install of 23.4 on a new windows 11 pc. When I use the web server on a different device, the buttons only work intermittently. They will depress and not activate (it will even show depressed on my pc running proscan). It can take several attempts to get the button to activate and "pop" back up. I have checked all my firewall settings, I'm logged in as a super user and can access from inside and outside my network. Any ideas?
ProScan
Software Provider
Ontario, Calif.
On a different device? Does it work properly on the other device?
Does the display seem to update normally?
Can you press the menu key once and see if it goes into menu.
I don't know what it could be other then make sure that ProScan is not minimized.
Dhouse900
It appears to not matter what device I use. I attached a picture of both the sds200 and 536HP showing the buttons pressed on the PC running proscan. That is what puzzles me and I don’t believe that’s from any firewall/virusIMG_4977.png
TintesB
Madison, WI
Does anyone know if the web-socket endpoint usable for an external website? I do have the web-server page visible to the outside world.
I'm trying to get the streaming details to be shown on an external website using web-sockets but so far I'm only getting small chunks of data such as (K,15:20:20,80934) which almost repeats but varies a bit sometimes.
If I view the web socket data from the internal web-server page on dev-tools I can see everything that it looks like I need.
Alternatively, is there a better solution for this? I see the "List of Parameters" section on the web-server page but am unsure how to use them for my situation. It feels like they might be there exactly for what I'm trying to do!
Any documentation that might help would also be highly appreciative!
