ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
ProScan Version 24.4 Just Released!
  • Added - SDS150 support except Bluetooth.
  • Added - SDS100 Headphone L/R Output option.
  • Added - Source Client & Web Server - Peak Listeners now shows time of occurrence.
  • Changed - RRDB Differences feature - The Differences label now indicates if there are differences.
  • Removed - Profile Editor - FTP Read & Write menu items on unsupported models.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
CKnobb
Central NY
I installed 24.4 on my Broadcastify feed PC. Proscan is showing 0 Current listeners, while the Broadcastify web feed shows 38 listeners. I did not submit a bug report yet as I'm not sure if this isn't something on my end I haven't figured out yet. Any other Source Client feed providers seeing this?
ProScan
Software Provider
Ontario, Calif.
View attachment 193825View attachment 193824
I'll look at it before the next release.
CKnobb
Central NY
I rolled back to v24.3 and the Current Listeners is operating as normal. Something broke it in 24.4. Not a huge deal. I can still monitor the Status Log to identify any Broadcastify connection issues for my feed if using 24.4. (y)
bearcatrp
Land of 10,000 taxes
Must be doing something wrong. Can import from RR. Can write to my 325P2. Am scanning what I imported but not hearing anything. Using my outdoor antenna. I know there is traffic because my R30 is hearing them fine. Made sure to check do not import encrypted stations. What am i missing? This is my 1st time using proscan with my 325p2. Usually just scan between frequencies but now am programming it. Appreciate any help.
ProScan
Software Provider
Ontario, Calif.
Did you import the sites near you and the groups containing the TGIDs?
Can you post the ProScan database text file here?
bearcatrp
I know about the limitations. I would at least get something but its totally deaf. Doesn't stop on anything. I have a search programmed to scan the P25 system. That picks up transmissions fine. But nothing on the upload from proscan.
