ProScan
Software Provider
Ontario, Calif.
Bob
nick223
Ottawa Illinois
The ProScan BCDx36HP Favorites Editor is under development. Anyone using my software knows that I put my heart into it and put as many features imaginable. The new ProScan Favorites Editor will be similar. Stay Tune!
I can't take any suggestions until this is done unless it's related to the new Favorites Editor.
Is this coming to a Home patrol 2 near me [emoji106]
ProScan
Software Provider
Ontario, Calif.
How about a ProScan SDR-based scanning app? :D
I'll put it on the list. Considering ProScan is 11 years in the making and the IOS and other platforms request. It may be some time before I can get to it. If I did everything on the list, this may be 20 years down the road.
JCoco100
Delaware, Ohio
PRO SCAN
Any idea why ProScan would bring the volume of the scanner all the way up and not let you adjust? I'm feeding audio and it's way too high. What would be a fix for this?
Thanks!
kb7gjy
Bonners Ferry, Idaho
Happy New Year Bob!!! I have had the best customer service from you then any other software publisher I have ever dealt with, including when I was building a new 911/dispatch center (read lotsa $$$$$$). Keep up the great work, can't wait to see what you will bring in 2017.
DB for the x36HP and maybe MDC1200 logging?
Honestly, Proscan is A++++ in my book
ak4fn
Fredonia, KY
Thanks!
What scanner are you using? Are you using the tape out or the headphone jack? Which input are you using for the audio in on your computer, the line in or the mic in? Do you have your mic boost checked on in windows?
gillham
Southern NH
I just stumbled across Windows 10 IoT. It's difficult to search just for "IoT" on the forum - curious if anyone has tried this on a RPi 3 with ProScan (or if it's even possible)?
I've got a spare RPi 3 from ADS-B tracking, but it's at work - so I can't play around, yet.
Edit: I'm guessing no, at first glance it looks like the application needs to be written specifically for Win 10 IoT, but utilizes some of the core features from Windows 10.
ProScan
Software Provider
Ontario, Calif.
Thanks!
Does the knob move up all the way up? If shut down ProScan, does it still do this? What type of scanner?
ProScan
Software Provider
Ontario, Calif.
Happy Near Year kb7gjy. Thanks, I'll do that.
JCoco100
Delaware, Ohio
BCD396XT. When the control cable is disconnected the volume will stay where I set it. When control cable is connected I can set the volume as I wish. However, as soon as radio traffic is present, it seems to auto ramp the volume all the way up on it's own. If I try to adjust to a lower setting it will ramp right back up again.
ProScan
Software Provider
Ontario, Calif.
I'm not very clear on this. Can you clarify.
Can or can not? These two statements sounds contradictory. You didn't mention the volume knob if that moves.
Adjust what setting? Windows Mixer?
Did you see the post from ak4fn, please answer the questions so we can help.
Syncopations
Hears voices in my head.
South Texas
I'm having this issue with ProScan 11.7 on the BCDx36HP scanners. In the video attached, you'll see what issue I'm having. Will uninstalling and reinstalling correct this issue? Also, I've been using ProScan to control both variants of the x36 scanners at the same time with no issues.
https://www.youtube.com/watch?v=aFAVJHj_7Ic
Thanks for your help.
