03msc
RF is RF
The Natural State
Bob any news yet on getting this fixed on the other scanner the Uniden BCD996P2 it dose not do this at all now i do realize that the Uniden BCD996P2 is a much newer scanner then the Uniden BCD79D but again i have no problems at with the other one only the BCD79D and iam doing everthing right to here's a another screenshot of the trunk type on and already to go if you can help in any way i would really appreciate it Bob From Tom. oh one more thing the input radio referencemenu ui no longer disappears whenever iam going from tab to tab no more ty ty for that Tom.View attachment 186128View attachment 186126
Unrelated question but what's stuff stuff in the right sidebar there? I don't think those are built-in to Windows so I'm assuming a third party app. Also... 3-ish months to upgrade to Windows 11! (unless you're paying for the security updates for another year). I don't like it, either, but it is what it is.
ProScan
Software Provider
Ontario, Calif.
@fxdscon
You use the ProScan Shortcuts? Correct. Can you help out this gentlemen if you have time. It's just been a while since I was in this area and will be starting a vacation this afternoon. I'll will point him to this thread. Thanks.
Good morning Bob,
I'm running Proscan VER 24.0. I'm using a BCD996P2. I've read through the manual concerning the shortcuts file, I'm wanting to add two shortcuts to upload and download from the scanner. I've looked at your examples but I'm still not sure how to add them. What I'm having trouble with is the structure of the commands. If this's not possible, no problem. The software is a great program. Thanks much for your help.
fxdscon
¯\_(ツ)_/¯
@fxdscon
Bob... I hope this answers the gentleman's question, and have yourself a great - and well deserved - vacation!
Good morning Bob,
If I'm understanding the question correctly (whether or not the ProScan shortcuts can be used to upload or download programming files to and from the scanner), I don't believe that is possible. The shortcuts that can be created fall into 3 categories:
  • Setting Volume values
  • Setting Squelch values
  • Automating only the set of functions that are otherwise available by manually scrolling through the scanner's on screen menu system and selecting and setting those items.
There are no functions available in the scanner's on screen menu system that would allow you to "Upload" or "Download" programming files, that would be a function of the ProScan software's database area.
There are functions in the scanner's menu system that you can use to manually create new programming of systems, groups, frequencies, etc. and all their many related parameters and settings in the scanner using a step by step, item by item process. Setting up the shortcuts needed to automate that entire process for any decent sized system would be far too cumbersome and time consuming. The normal process of creating programming files with the Proscan software and writing to the scanner would be a far better path.
Hope that helps, and let us know if you have any further questions.
TFOX9
TFOX9
to your
Unrelated questions the stuff you see on the right is called Windows 10 Gadgets and you are 100% correct they are in no way shape or from a part of the operating system of windows, and i really don't knows what iam going to do you can still keep the os with out upgrateing to the brand new os, evening with out the updates. Is it wise to do? absolutely not but it can be done in fact a lot still are today with out any problems at all. the only one problem i do see is when other software companies start phasing out the os, now i did just purchase a brand new laptop with the news os that i can get used to it plus i needing one and i can see if i like this brand new os or not. and if iam going to slap it on this one or not.
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
I have a "UBCD996P2" which I can have running with ProScan however this is under a BCD996P2. I have to use external software to program it. Is there any plans on adding support for this model?
Thank you
Pr999
WRYF747
Plainwell, Michigan
Proscan appears to have an issue with copying groups between pre-config and modifying the GPS data of those groups, as it somehow ends up corrupting that pre-config in the process. This issue can also create a ripple effect after you fix one of the groups (redownloading and reassembling them) and reupload. It triggers a statistical error and refuses to download that group and anything below that group. I've never had this issue before, until the last update.
GTR8000
NY/NJ Database Guy
BEE00
Thank you
I'm confused, how exactly were you using ProScan to program it 5 years ago? :unsure:
VK3YMML
VicScan Forum Owner
Melbourne, Victoria
'Apologies I have a "UBCD325P2" but when I choose the scanner "BCD325P2" it wont seem to communicate when I attempt to download or upload to the unit
ProScan
Software Provider
Ontario, Calif.
Thank you
See the Bug & Suggestion link on the proscan.org website.
dave3825
Suffolk County NY
Proscan or Radio Reference db issue?
MTA MRRS has a new site listed in the database and Proscan is not seeing it with RRDB differences.
The site was added today.
If I import the whole system, its there. If I move the site from the import into the existing system, and run RRDB, it wants to delete the site.
Its not seeing it on Radio Reference.
ProScan
Software Provider
Ontario, Calif.
I'm loving this version! One thing I noticed while messing around with the profile editor is that when you try to write to the scanner via FTP, the scanner goes into FTP lock mode and restarts (as expected), but it doesn't actually write the profile. However, it will write the profile just fine if the scanner is in MSM, and you select "scanner write".
It works for me. If after the next release, it still doesn't work, send me a Bug Report via email.
Bug Reporting and Suggestions
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
Am I reading the manual correctly for the Broadcast L/O, that I could have channel such as a med patch to hospital in my scanner feeding audio to proscan and it will still record it but not pass it on to broadcastify when put inside the file?
Am I doing something wrong? I enabled the quick keys I want to hear, and added them to the file, but they still stream to broadcastify. See attached file.
  • Broadcast Lockout - Source Client.txt
billyfromhill
Anybody know why when recording with an SDS200, some trunking calls are not putting the UID in the file name even though the UID is being logged in the recording tab? I am using the %U1 parameter in the file name. The calls are not always short transmissions either, sometimes a call of 5 or 6 seconds or even longer it will still fail UID in the name of the MP3 file.
