ProScan
Software Provider
Ontario, Calif.
Bob
4436time
In Gov't We Trust
Colorado
Is there any possibility of adding a checkbox that instructs the app to revert back to the user defined display view when closing the Favorite and Profile Editors?
ProScan
Software Provider
Ontario, Calif.
I don't understand. The display view doesn't have anything to do with the Favorites Editor or Profile Editor. The display should stay the same after closing the Favorites Editor or Profile Editor.
If you have a suggestion, see the link on the proscan.org website like buddrousa posted above.
4436time
In Gov't We Trust
Colorado
Correct and email sent.
dimab
CT
are older versions of ProScan available for download?
I have a Win7 SP1 machine running, but .Net 4.8 will not run on Win7.
Need a version of ProScan that targets a lower version.
kb0ap
Have someone got it to work properly with an iPhone 16?
I came across this great software last night looking for only one thing = listen to my SDS100 while I am in different parts of the house. I've downloaded the full version as I am very happy to pay for it if it works for my intend, got it to work meaning that I can start the server and access it from my iPhone. I can listen (have some weird noise which I have to figure out later but I am quite sure is something with the 3.5mm cable from headphone to the mic of the computer) but the display/controls doesn't respond at all. The only button that works in the webpage is the play but after hit play I can listen but no way to at least change channels. I've tried with Brave browser and with Safari as ChatGPT recommended but the same behavior. Any idea? Thanks in advance.
W8WCA
/usa/oh/cmh EM89kx
Web Server Certificate expired:
I have it set and forwarding 5000 and 80 to the computer ProScan runs on (Like I have for a long time) . I check for port 80 with one of the web sites to make sure it is open - it is open.
But when I try to update or replace Lets Encrypt it says "Http-01 Challenge Fail Check port 80"
I use dynv6.net and it has my current IP - and I have ProScan set to my external IP in the Web Server Main Tab
I put my dynv6.net donaim in like it has always been
But I cannot get a new Cert or update it.
Where should I start?
ProScan
Software Provider
Ontario, Calif.
Do this:
1. If the Web Server in ProScan is running, check that it's not using port 80.
2. Check and double check your antivirus software is not blocking the connection.
3. Reboot the computer.
If it still doesn't work then see if you can obtain the cert using Certify The Web
W8WCA
/usa/oh/cmh EM89kx
Do this:
Certify The Web worked! Thanks (I have checked MS SDefender and even turned windowss firewall off & web check sites show port 80 OK/open)
dimab
CT
ProScan running on Mac ARM64 inside VMware Fusion - Windows 11.
Seeing very bad redraw speed on the graphics of the ProScan app. Resizing or moving the ProScan window can take several seconds with very slow refresh rates as well only in the ProScan window.
All other apps in the VM seem to work just fine.
screen recording here - https://drive.google.com/file/d/1efVLxQGrgbH_g0xOIWae1qzpukKzz-o4/view?usp=drive_link
Is anyone else seeing this behavior?
fxdscon
¯\_(ツ)_/¯
In Proscan 24.3 The virtual scanner image has a annoying overlap. Will you please fix it?
You can report ProScan bugs here:
