ProScan
Software Provider
Ontario, Calif.
Bob
sunwave
Oklahoma
That's by design. I'm not going to change it as it's been like that forever.
That image for the BCD325P2/BCD996P2 needs to be updated. The actual BCD996P2 buttons don't even touch it's screen's black border. I waited to find out what your reply is as the deciding factor whether or not I purchase beyond the 30 day trial period. Everything else is fine. After that I will stick with ARC XT Basic until you fix it or replace it with a better virtual scanner image.
Whiskey3JMC
Simulcastylvania, TE
SERIOUSLY??? Is it really THAT big of a deal as to be THE deciding factor if you purchase? But do they function as intended????? Not like they overlap usable real estate or anything. PUH-LEASE!
VK3YMML
VK3VSN / VicScan Forum Owner
Melbourne, Victoria
UIDfile
I have multiple scanners running through Proscan and have been utilising the UIDfile to map out who is talking to who.
However when I run multiple versions for different scanners there is overlap.
Can I load a different UIDfile for each scanner that is connected to the computer?
Whiskey3JMC
ProScan
Software Provider
Ontario, Calif.
I will have another look later and see. I have up to 6 different scanners on the same PC
Yes, as everyone is pointing out, you need seperate folders so the config and logging will apply to just one scanner.
Per the FAQ
Q: Can I run multiple copies of ProScan or RadioFeed on one computer?
A: Yes. Many instances of ProScan or RadioFeed can run on the same computer. Copy the contents of the ProScan or RadioFeed folder to a new folder. Change the Comm Port setting and other options specific to that instance.
VK3YMML
Melbourne, Victoria
Per the FAQ
Roger. That might make life a bit easier
MilAirNJ
South NJ
IMG_4378.jpegSome talkgroups just stopped recording. Running proscan 24.3. It appears to be the same talkgroups that are not recording. I am running an sds200 via wireless. I’ve enclosed a picture to show.
