For long Unit IDs:
Unit ID Name 1 is the first 16 characters, Unit ID Name 2 is the second 16 characters and so on.
Okay thanks. I wasn't too sure. Its pretty long if someone puts more than 16.
For long Unit IDs:
My band-aid is as follows
1. Ensure proper NAC is entered for site/sites.
I'm glad you posted this because I was wondering about this too. For the past few days I've also been using the proper NAC for each P25 site I monitor and it really does feel like it does better and more solid tracking.
In other news, I'm REALLY liking the backlight behavior now more than ever. I have it set to:
Squelch: Open Squelch
Keypress: 15 Seconds
And it works as I would expect, Backlight off, LED blinks every few seconds, squelch opens, backlight turns on, stays on during transmission and when it ends, stays on for the duration of the channel delay and then turns back off, repeat.
2. If the above does not eliminate the issue note sites CC and VC frequencies that are causing the stuttering issue.
A. Manually enter the frequencies in quick search mode and apply IFX (FNC + 7) for each frequency.
These steps eliminated my issues I was having in my area and YMMV.
If you still have stuttering issues after attempting the above steps, I'd then created a log and zip it to post here. Houk
Why is it, that in the Sentinel software, some P25 systems have no option to set the P25 NAC, or the option is greyed out?
It is. After checking again, it seems that if you have the system type set to "P25 Trunk", you have the P25 NAC option available, but if the system type is set to "P25 X2 TDMA", there's no option to set the P25 NACEnsure Target Model is set to SDS100.
Houk
Does P25 X2 TDMA use a NAC? If they do I'll submit a bug report.
Houk
I've got two phase 2 systems within range of me. According to DSD+, they do.
Jason I think you might have something here. I searched the NAC code and lock it in or I mean set to that code and noticed a difference. I'm still having fun with my SDS-100 and with your help and many others I'm learning day by day on how to get the best from this scanner and my Uniden Bearcat scanner is acting like a Bearcat the best in the business.More testing was done today for the following issue as the FW update did not fix:
http://forums.radioreference.com/un...irmware-1-02-05b-open-beta-3.html#post2956805
My issues was what many other RR Users are experiencing when the SDS would stutter from CC to VC on P25 systems where the sites RSSI values that should be around -90 was actually displaying values of -45 plus.
Houk
The P25 available options are:Are they Phase II or X2?
P25 Trunk
P25 X2 TDMA
P25 One Frequency
X2 TDMA is Phase 2.
