SDS100/SDS200: SDS100 Firmware 1.03.03M/1.01.05S Open Beta
Badboy536
I still perfer firmware 1.02.05b .it Definitely works better here in Los Angeles for LAPD.and seems to be more Sensitive on receive both digital and analog. The latest Beta firmware does not decode LAPD as well and the MTA Metro bus lines edac always lose's the signal when its full bars on the signal meter.the 1.02.05b does not do this.
scanner_geek
FL Mickey Mouse World & Minnesota ARMER
Excuse me guys, how can I get my logs and post them ? Is there a .TXT file I can copy, zip and post ?
Can someone show me how and I will post what I have for South Florida.If this was covered could someone send me a link ?
hiegtx
Dallas, TX
See this for how to create a log.
rbrtklamp2
Dupage County, Illinois
The NAC is irrelevant in this case. The radio is deaf no matter what mode or band it is in. VHF, AM, FM, FMN, 800 -Edacs/ P25 PI doesn't matter, all I receive is rythmic kerchunking.
I have instructions from Jenna at Uniden and the unit is going back this week as soon as I get off shift.
~S~
___
Mine was doing the same thing, so back it went yesterday.
Before that it was working flawlessly here. It just stopped receiving.
Just wondering guys what where the serial numbers associated with your units? I have a fairly low serial number of 44 I want to keep the radio as kind of a collectors unit but now you have me wondering if there maybe a hardware issue to look out for?
Thanks,
Bob
Sent from my SM-N910V using Tapatalk
Firmware version 1.02.5B Main with 1.01.05 Sub works better in Los Angeles for LAPD (clear reception)
WX4JCW
Stow, Ohio
I’m not having issues with #1679
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
XPR7550 - SDS100
jonwienke
More Info Coming Soon!
VA
Record and post a debug log so the firmware engineers can determine why. A general statement that reception isn't as good does not help identify and resolve the problem.
WX4JCW
Stow, Ohio
im noticing that while trunking a P25 system the NAC is not always transmitting, sometimes even the other data such as WACN and RFSS ID,
if i have a NAC set for a site, will i miss transmissions?
UPMan
In Memoriam
Arlington, TX
Yes. But I believe NAC is always being sent. So, the issue might be poor receive quality. What is RSSI, NOISE, D-ERROR?
Badboy536
I have to agree that's exactly what I'm using the new Beta just doesn't receive that well in Los Angeles
UPMan
In Memoriam
Arlington, TX
That is not an actionable report. Without logs and more descriptive than provided, there is nothing we can do.
WX4JCW
Stow, Ohio
Decode Errors are not over 5 actually, Noise is Fluctuating between 700-14000 but voice decode is perfect, no audible dropped packets
the data is not consistent now i am not missing any transmissions on the Ohio Marcs Columbus Simulcast with the site nac enabled, the data display just drives me nuts
scrotumola
So. Texas
Thanks,
Bob
I have numbers 45 and 579. 45 Is performing at about 75%.... 579 is one that is deaf and will be shipped to Uniden this weekend.\
ecarvalho
is that the last set of digits?
mine ends in 016
Sent from my iPhone using Tapatalk Pro
bob-k
Colfax NC
I may have oopsed
Previously I did firmware updates through the Sentinel but now I wonder if I did it right. I did it by way looking in the firmware folder no opdates there. So I did it by way of the zip file copy and pasted then fired up the scanner and looked found the Firmware was updated.
My question do I need to update the two older updates which know I know was not orrectly done or is it built into the new firmware? Do I back update my firmware or is it up to date now Main 1.03.03 Sub 1.01.05.
Thanks guys!
UPMan
In Memoriam
Arlington, TX
All firmware completely replaces previous versions. Note that you really should only be doing these public beta versions if you are wanting to test against improvements to reported issues and want to provide log files in the event you experience issues that are not yet resolved.
GrandpaFrank
Can you tell me where to find that firmware please? Also, I tried downgrading "after flashing zip from post #1" and the scanner doesnt seem to downgrade. It's like the x36hp where you just put firmware in the firmware folder on sd card and reboot scanner right?
