SDS100/SDS200: SDS100 Firmware 1.03.03M/1.01.05S Open Beta
ScanKent
Unable to receive/track EDACS system
Unable to receive/track Consumers Energy Statewide EDACS system with the SDS100. BCD396XT works as expected. Log file attached. Noise was normally under 1000. A couple different times it left the control channel and was scanning. At that time, the noise level was all over the place. I've moved around and went outside and still not working. RSSI is normally -50db to -80db.
One other thing to note, it does receive/track a digital/data talkgroup. The ID comes up and I hear the data. Analog is what I am having issues with. I also just heard an "i-call' so that received/tracked okay.
While I'm here, why does the signal bar and system data (SysID, RFSS, SiteID) flash when held on a site? It does this on P25 and the EDACS system in question. P25 receives MPSCS just fine (as long as it's in my favorites and NAC is correct or in search mode). Priority is off and the radio never misses a channel grant so I think it is always receiving and really isn't going away every second.
Firmware Main: 1.03.03
Firmware Sub: 1.01.05
EDACS System link: https://www.radioreference.com/apps/db/?sid=1579
  • log0044130-EdacsSystemNotWorking.zip
tpp517
Dennis, MA
Uploading these logs from CT State Police Troop E and the Waterford CT P25 system, I am missing one side of the transmission.
  • log0040773.txt
  • log0085219.txt
  • log0089510.txt
  • log0091587.txt
bob-k
Elizabeth NJ
Okay Paul
All firmware completely replaces previous versions. Note that you really should only be doing these public beta versions if you are wanting to test against improvements to reported issues and want to provide log files in the event you experience issues that are not yet resolved.
Okay Paul beta vs of Firmware is for testers, Thanks!
Bob
UPMan
In Memoriam
Arlington, TX
There is no need to apply older firmware before more recent firmware. Just load the latest one you want. All updates completely erase previous updates, so applying them first serves no purpose.
nessnet
Eastside of Lake WA
what Public updates are there
Can someone link me to all public updates I will update oldest first!
I'd also like to obtain the last public SDS100 firmware please.
Sentinel 'sees' the beta as the latest version and thus won't DL the last public version...
jonwienke
More Info Coming Soon!
VA
You'll find the last firmware applied by Sentinel in this folder:
C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater
Copy from there to the firmware folder on the scanner to revert.
RCjim
New York
Firmware version 1.02.5B Main with 1.01.05 Sub works better in Central NY also.
Scanningar
Arkansas
System monitored: Arkansas Wireless Information Network (AWIN) - Little Rock Simulcast Site
https://www.radioreference.com/apps/db/?sid=3918
1. Improved reception on P25 trunked systems.
Result: I am very happy to report that this firmware is working great on my local system. This simulcast system has always been very tough to monitor (especially at my home which is nearly between two simulcast tower sites). I am still getting a few missed comms. or high decode error rates. However, these are mostly while mobile in a vehicle, and I suspect to be mostly signal related.
2. Improved reception for short communications on trunked systems.
Result: Appears to be fixed. A few here and there, but nothing like the issues of previous versions.
There are two issues I have discovered:
Log log0101543.txt: This may be by design, and is not new to this firmware version. While in ID Scan mode, if I press the Dept key, and then immediately turn the knob to select a specific department, the scanner will disregard the hold and return back to ID Scan mode. If I press the Dept key, and wait for it to hold the first department displayed, I can then press Dept again and tune around to the desired department and it will properly hold.
Log log0278349.txt: This appears to be new to this version. During normal scan mode, pressing to hold on a talkgroup causes the backlight to remain always on. Pressing to hold on a talkgroup and immediately turning the knob to select another does not exhibit this problem. Manually turning off the backlight using the power button or releasing the hold resumes normal backlight operation.
Thanks!
  • SDS100-BetaLogs.zip
werinshades
Chicago , IL
Recording Feature
I'm not sure which firmware this began, but according to the owners manual, recording should shut off when unit is powered down. I had the recording on yesterday, shut down the scanner and charged it up overnight. This morning the Record feature was still on despite I didn't reactivate it when I powered it up:
"START/STOP RECORDING
While scanning, press Func then Replay/Reccord.
Resets to Off when you turn off the scanner"
W1KNE
PITA from New England
New England
1.03.03 still having some severe UHF image issues.
Not sure if this was supposed to be addressed in this or not.
I will post the debug files tomorrow. I apologize for not doing so in this reply.
rbrtklamp2
Dupage County, Illinois
I've noticed the same thing especially when in a strong UHF environment with many different UHF repeaters in a local area like down town Chicago. Well actually across most of the city IFX does not help and ATT doesn't do much to help either when all of my other scanners perform great on the analog UHF Band except for my 436HP which I have to send in to have fixed soon due to display and clock issues as well. But I still think this release has had the best results with P25 systems sounding very clear and having very few dropped transmissions compared to prior releases also they finally fixed the P25 patch bug with this release which was a very big plus for me.
Sent from my SM-N910V using Tapatalk
UPMan
In Memoriam
Arlington, TX
According to the logs, the scanner seems to scan the below. If this is not correct, please post specific links to the systems.
Motorola
https://www.radioreference.com/apps/db/?sid=832
P25
https://www.radioreference.com/apps/db/?sid=6344
Others
856.2375 MHz
857.2375 MHz
These frequencies have never been received.
1. Which site has issues?
2. Is it resolved if you only scan the one site?
UPMan
In Memoriam
Arlington, TX
According to the log, the scanner loses that control channel frequently.
The signal is very very weak at those situations or there is some interference.
Please recheck the firmware version, and each setting, and the antenna, and connection to it, and presence of interference.
Especially the sub firmware version is more important for EDACS reception.
ScanKent
I made another log file while outside where it stayed on the control channel. I see the TG and voice channel in the log file. TG 559 was chatting away during the debug file recording. The radio does not attempt to switch to that channel. It stays on the control channel. And i-calls and digital/data track.
Firmware versions are correct. Antenna connections are good. No interference heard while listening to the control channel on direct frequency entry.
Thanks.
ScanKent
Here is the log file.
  • log0855197-Edacs2nd.zip
