2023 VHF Low Band Logs
kkn50
Long Time Member
Hill Country Village, Texas
South Texas Logs
BCD996XT Scanner w/ ten meter dipole
Good opening to California late last night (4/17/23)
25.9500 CSQ Carrier with no audio. KOA?
30.0750 150.0 US MIL - "Liberator" w/ radio checks
30.2250 CSQ Asian fishing fleet
30.5800 CSQ "Kyle Hill truck came in at 24 88"
30.7750 CSQ Asian fishing fleet
30.9200 167.9 First Student Inc, School Buses, Kent RI
31.1000 CSQ Asian fishing fleet
31.2000 203.5 Taxi in Spanish. Possible Alajuela, Costa Rica
32.1800 77.0 Taxi, Alajuela, Costa Rica
32.9400 141.3 Taxi, Costa Rica
34.2000 150.0 US MIL - Helo
36.8750 150.0 US Mil - "Liberator" w/ radio checks
39.3400 162.2 CA HP
39.4000 162.2 CA HP
39.8000 162.2 CA HP
40.6700 CSQ SNOTEL w/ full scale signal
40.9250 150.0 US MIL - Helos "Landing runway 31 left" "the triangular strip south of the RV park" "back to the parade field, and we'll run till our bingo, then back to K-SAT (San Antonio International Airport)" "how far is College Station from here? About 100 miles"
42.5600 118.8 CA HP
44.9400 186.2 CA HP
45.0200 192.8 CA HP
45.5000 192.8 CA HP
45.5200 186.2 CA HP
45.7000 136.5 CA HP
kkn50
Long Time Member
South Texas Logs
30.3000 CSQ Asian fishing fleet
30.7500 150.0 US MIL
32.1800 141.3 Taxi, Alajuela, Costa Rica
38.6600 173.8 Taxi dispatch in Spanish - band open to Central/South America
KF4ZTO
kkn50,
30.5800 MHz FM [CSQ] might be C.W. Wright Construction Company. I’ve logged them (locally) using carrier squelch as well as the more commonly associated with them PL tones. It seems like they have one of the channels in their lowband radios programmed with carrier squelch. As an aside, they are slowly migrating to the standard VHF high band itinerant frequencies; but all their trucks still have a low band antenna on them, or a low band antenna and a 1/4 wave VHF high band antenna.
Very quick band scan around 8:00pm local time to 8:20pm local time. Hearing the fishermen chatting away on
29.8250 MHz FM [CSQ]
30.7000 MHz FM [CSQ]
30.7750 MHz FM [CSQ]
30.8000 MHz FM [CSQ]
30.9500 MHz FM [CSQ] very weak
31.1000 MHz FM [CSQ] very busy
31.7000 MHz FM [CSQ]
31.8000 MHz FM [CSQ]
Other logs:
25.9500 MHz FM [CSQ] - Unmodulated carrier - has been coming in basically daily for weeks and weeks now, if not months. Often it’s a better band opening indicator than WWV!
29.8500 MHz FM [CSQ] - Data, possibly paging
31.2000 MHz FM [67.0 Hz] - mic key up, followed by data burst.
31.2000 MHz FM [203.5 Hz] - Taxi dispatch
32.1800 MHz FM [141.3 Hz] - Taxi dispatch, good signal
33.0000 MHz FM [CSQ] - Data bursts, probably related to the fishing fleet radio networks
KF4ZTO
20-April-2023
Between 1315 and 1330 local time:
30.4500 MHz FM [150.0 Hz] - Several transmissions heard, barely coming through, although signal strength seemed to be improving
31.2000 MHz FM [203.5 Hz] - Just barely making it, the usual Spanish language taxi dispatch
32.1800 MHz FM [77.0 Hz] - Got enough for a tone squelch decode
32.9400 MHz FM [141.3 Hz] - Very weak, taxi dispatch
32.9500 MHz FM [150.0 Hz] - Decoded tone squelch as 151.4 Hz but the signal had all the characteristics of a military signal (wide FM deviation) - strong mic key ups, no audio heard
KF4ZTO
Quick monitoring session between 1615 or so local and 1700 local.
I believe this is the first time I’ve actually been able to hear the taxi dispatcher on 38.660 MHz FM [173.8 Hz PL]
25.9500 MHz FM [CSQ] Carrier, very dramatic fading
26.9950 MHz FM [CSQ] RCRS - lots of data bursts mixing together
27.2550 MHz FM [CSQ] RCRS - basically nonstop data!
29.7750 MHz FM [CSQ] Asian fishery radio chatter
29.7800 MHz FM [CSQ] Strong FSK signal
29.8250 MHz FM [CSQ] Asian fishery radio chatter
29.9500 MHz FM [CSQ] Weak FM signals, fishing fleet radio network
30.0000 MHz FM [CSQ] FM carrier, faded up out of the noise and then rapidly disappeared
30.0000 MHz FM [CSQ] Asian fishery radio chatter
30.1000 MHz FM [CSQ] Paging
30.3000 MHz FM [CSQ] Asian fishery radio chatter
30.5500 MHz FM [CSQ] Asian fishery radio chatter
30.8000 MHz FM [CSQ] Strange “pulsing” data (??) signal, not OTHR
30.8000 MHz FM [CSQ] Asian fishery radio chatter
30.9500 MHz FM [CSQ] Data
31.0000 MHz FM [150.0 Hz] keyup, no voice
31.0750 MHz FM [CSQ] Asian fishery radio chatter
31.1000 MHz FM [CSQ] Asian fishery radio chatter
31.2000 MHz FM [203.5 Hz] taxi radio dispatch (Spanish language)
31.6000 MHz FM [CSQ] Asian fishery radio chatter
31.8000 MHz FM [CSQ] Asian fishery radio chatter
32.2000 MHz FM [CSQ] Asian fishery radio chatter
33.0000 MHz FM [CSQ] Data
33.7000 MHz FM [CSQ] Asian fishery radio chatter
34.0500 MHz FM [150.0 Hz] carrier for a few seconds
35.0000 MHz FM [CSQ] Asian fishery radio chatter
35.6000 MHz FM [CSQ] Paging, heavy fading
36.2500 MHz FM [CSQ] Data bursts, previously monitored on this frequency during band openings
36.3000 MHz FM [CSQ] Data
36.5000 MHz FM [74.4 Hz] taxi radio dispatch (Spanish language)
36.9000 MHz FM [150.0 Hz] microphone keydown? heavy fading
37.1200 MHz FM [74.4 Hz] Data - SCADA
38.2500 MHz FM [???] FM carrier, very weak, fading in and out of the noise
38.6600 MHz FM [173.8 Hz] taxi radio dispatch (Spanish language)
KF4ZTO
Afternoon listening 26 April 2023 VHF low band DX. VHF low skip.
Start: 1415 local time. End: 1445 local time (eastern daylight time).
Receiver: Pro-651 (Pro-106) with HYS telescopic 27 MHz CB antenna (51 inch antenna) with top section collapsed.
30.0000 MHz FM [CSQ] Carrier, fading
30.4500 MHz FM [150.0 Hz PL] Fort Hood, also lots of fading
31.2000 MHz FM [203.5 Hz PL] Taxi dispatch, weak but readable
32.9400 MHz FM [141.3 Hz PL] Taxi dispatch
35.1800 MHz FM [162.2 Hz PL] Tow truck service (California) - very weak
35.5000 MHz FM [CSQ] Paging
36.3000 MHz FM [CSQ] Data, previously monitored during band openings
36.5000 MHz FM [74.4 Hz PL] Taxi dispatch - Spanish language
36.6000 MHz FM [CSQ] Weak…something - unable to positively ID. Could be a carrier, or the YSD beacon (which I haven’t heard in a while) or something else
37.1000 MHz FM [150.0 Hz PL] US military - Radio checks, did not copy a callsign
37.1200 MHz FM [74.4 Hz PL] SCADA data bursts
38.6600 MHz FM [173.8 Hz PL] Taxi dispatch, came in full scale at tune in, then faded down into the noise, rapid fading back up to full quieting. Best I’ve heard this system so far. Could hear the base station and the mobiles replying on 38.660 MHz 173.8 PL.
40.1750 MHz FM [118.8 Hz PL or CSQ?] Strong carrier, unmodulated…then heard data in the background. Lots of AC hum or other similar noise on signal. Scanner decoded 118.8 Hz tone, which I believe is due to the AC hum but I could have just been hearing the tone squelch. Equally strong on 40.1700 MHz FM and 40.1800 MHz FM
40.6700 MHz FM [CSQ] SNOTEL - deep fades
kkn50
Long Time Member
South Texas Logs
39.3400 162.2 CA HP
40.1250 150.0 US MIL "Eagle 03"
40.6700 CSQ SNOTEL
44.9400 186.2 CA HP
45.0200 192.8 CA HP
45.5000 192.8 CA HP
marvinsuggs
Richmond, TX
April 2023 Richmond,TX Bearcat BCT15X scanner Sirio GPA 27-45 MHz ground plane antenna.
30.60 CSQ ? Carrier
30.70 CSQ ? Spanish
30.72 77.0 ? Calling 158
30.78 CSQ Asian
30.92 167.9 First Student, Warwick, RI
31.00 D754 Little Britain Ag Supply, Lancaster Co, PA
31.02 97.4 ?
CSQ ?
31.04 71.9 ?
31.10 CSQ Asian Fishermen
97.4 ?
31.12 100.0 Secco of Palmer Bus, Hampden Co, MA
31.20 203.5 Taxis, Alajuela, Costa Rica?
31.24 136.5 Eastern Car Svc, Brooklyn, NY
D131 First Student. Norwich, CT?
31.70 CSQ Asian Fishermen
31.80 CSQ Asian Fishermen
33.44 179.9 Tolland Co, CT FD
33.46 114.8 Provincetown, MA FD
33.48 114.8 Barnstable, MA FD
33.58 114.8 Yarmouth, MA FD
33.64 114.8 Bourne, MA FD
33.66 179.9 Norwich, CT FD
33.78 114.8 Falmouth, MA FD
33.84 131.8 Uxbridge, MA FD
42.92 162.2 California HP, El Centro
43.04 107.2 Kinney Contractors Statewide, IL
43.40 77.0 Ingram Readymix, Houston, TX
43.44 77.0 Ingram Readymix, Houston, TX
44.58 CSQ BNSF Hy-Railrail Compliance System
46.46 CSQ Baltimore Co, MD FD
47.88 CSQ ?
KF4ZTO
Marvinsuggs, chances are the comms you're hearing on 30.78 MHz are actually 30.775 MHz (if its fishery radio comms). 30.775 MHz FM [CSQ] is one of the busier frequencies for those networks, at least in my monitoring. It's almost as consistent as 31.1 MHz FM [CSQ] or 31.8 MHz FM [CSQ].
Logs from 27 April to yesterday 1 May 2023. Richmond, VA. Portable receiver (Pro-651, same thing as a Pro-106) with a HYS 27 MHz CB telescopic whip antenna.
29.7750 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 29.775MHz
29.8000 MHz FM [CSQ] - POCSAG paging - likely European origin
29.8250 MHz FM [CSQ] - Asian fishing fleet radio chatter, weak - FM fishery radio 29.825MHz
29.8500 MHz FM [CSQ] - POCSAG paging - likely European origin
29.9500 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 29.950MHz
29.9500 MHz FM [CSQ] - POCSAG paging - likely European origin
30.2000 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 30.200MHz
30.3000 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 30.300MHz
30.4500 MHz FM [150.0 Hz PL] Decoded as 151.4 Hz PL - Fort Hood Range Control
30.7750 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 30.775MHz
30.9000 MHz FM [CSQ] - FM carrier, very deep fades, then back to almost full quieting
30.9500 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 30.950MHz
31.1000 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 31.100MHz
31.1500 MHz FM [CSQ] - POCSAG paging - very rapid bursts - European origin
31.1500 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 31.150MHz
31.2000 MHz FM [203.5 Hz PL] - Spanish language taxi dispatch - MDC1200 "squawk" readable even in poor conditions
31.8000 MHz FM [CSQ] - Asian fishing fleet radio chatter - FM fishery radio 31.800MHz
32.1800 MHz FM [77.0 Hz PL] - Taxi cab dispatch - Costa Rica
32.1800 MHz FM [141.3 Hz PL] - Taxi cab dispatch - Costa Rica
32.9400 MHz FM [74.4 Hz PL] - UNID user, possibly a bad tone decode
32.9400 MHz FM [77.0 Hz PL] - Taxi cab dispatch - Costa Rica
32.9400 MHz FM [118.8 Hz PL] - Strong "pulsing" data or over the horizon radar, 118.8 Hz tone decoded immediately
32.9400 MHz FM [141.3 Hz PL] - Taxi cab dispatch - Costa Rica
33.0000 MHz FM [CSQ] - Weak FM chatter, presumably Asian fishery radio
34.0500 MHz FM [150.0 Hz PL] - Decoded as 151.4 Hz, FM carrier [previously monitored on this frequency]
35.1800 MHz FM [162.2 Hz PL] - Tow truck dispatch (California)
36.2500 MHz FM [CSQ] - Rapid data bursts
36.3000 MHz FM [CSQ] - Data, UNID source, possibly fishery related
36.5000 MHz FM [74.4 Hz PL] - Taxi cab dispatch - Latin America
36.6000 MHz FM [CSQ] - YSD Beacon - CYSD Heliport - very poor copy, but I heard the tell-tale long tone burst after Morse ID
38.6600 MHz FM [173.8 Hz PL] - Taxi cab dispatch - Latin America, very dramatic fading
39.0000 MHz FM [CSQ] - FM carrier, unknown source
39.5400 MHz FM [CSQ] - Virginia SIRS (statewide law enforcement mutual aid) - BOLO callout, weak (likely groundwave) 39.54MHz
marvinsuggs
Richmond, TX
Thank you!
kkn50
Long Time Member
South Texas Logs
26.1100 FM KOVR (channel 13) Sacramento Television Stations Inc - Broadcast Auxiliary Remote Pickup w/ strong signal
30.3750 CSQ Asian fishing fleet
30.5000 CSQ Asian fishing fleet
30.7500 CSQ Asian fishing fleet - very active w/ strong signals
31.8000 CSQ Asian fishing fleet
32.7000 150.0 US MIL
36.5000 74.4 Taxi dispatch in Spanish
W8HDU
Lima, Ohio
South Texas Logs
Your logs from TX are impressive. I wish we were as active here as you and others have been. But I've also not seen anything logged from NW Ohio. So I might be in a bad location. Although, I did get an e-mail from a fellow in Washington state who heard one of our low band transmissions.
The 26.1100 is interesting as it appears they are running from multiple sites. I suspect they are using it as perhaps a crossband repeater, using UHF transmission to a site, and then 26.11 to pop back to the studios/offices. License attached. Note the expiration date, which is not unusual these days.
  • KMK282.pdf
KF4ZTO
Logs 3 May 2023 and 4 May 2023
29.7100 MHz FM [192.8 Hz PL] Spanish, weak
29.7500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 29.75 MHz
29.7700 MHz FM [167.9 Hz PL] Spanish
29.7750 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 29.775 MHz
29.8000 MHz FM [CSQ] Weak paging (POCSAG) 29.8 MHz pager
29.8000 MHz FM [CSQ] Carrier, deep fades
29.8250 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 29.825 MHz
29.8400 MHz FM [CSQ] FSK signal
29.8500 MHz FM [CSQ] Pager - POCSAG - European origin (I think)
29.8750 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 29.875MHz
29.8875 MHz FM [CSQ] FSK signals
29.9000 MHz FM [CSQ] Weak FM voice, probably fishermen fishery radio chatter 29.9 MHz
30.0500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.05 MHz
30.1000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.1 MHz
30.3000 MHz FM [150.0 Hz PL] Military, convoy ops? Decoded tone as 151.4Hz 30.30 MHz FM
30.4000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.400 MHz
30.4500 MHz FM [150.0 Hz PL] Decoded as 151.4 Hz - Fort Hood Range Control, very deep fading
30.5000 MHz FM [CSQ] Strong “pulsing” data signal
30.5000 MHz FM [ ??? ] Weak FM voice, UNID
30.6000 MHz FM [CSQ] Data, maybe paging
30.6750 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.675 MHz
30.7000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.7 MHz
30.7500 MHz FM [CSQ] Data
30.7500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.75MHz
30.7750 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.775MHz
30.8000 MHz FM [CSQ] “Pulsing” data signal, similar to signals heard on 33.000 MHz and 30.500 MHz previously
30.8000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.8 MHz
30.8750 MHz FM [CSQ] MFSK data bursts heavy fading / QSB
30.8750 MHz FM [CSQ] Weak FM voice,
likely active fishing fleet fishery radio comms 30.875 MHz
30.9000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.9 MHz
30.9000 MHz FM [79.7 Hz PL] UNID - Business radio? 30.900 MHz
30.9500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 30.95 MHz
30.9500 MHz FM [CSQ] Data bursts
31.0000 MHz FM [CSQ] Fishery radio, weak fishermen radio chatter 31.0 MHz
31.0500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.050 MHz
31.0750 MHz FM [CSQ] Fishery radio Asian fishing fleet chatter 31.075MHz
31.1000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.1 MHz
31.1200 MHz FM [CSQ] Paging - POCSAG
31.1500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.150 MHz
31.2000 MHz had multiple users on at once
31.2000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.2 MHz
31.2000 MHz FM [67.0 Hz PL] Spanish, not taxicab, likely another LMR system
31.2000 MHz FM [203.5 Hz PL] Taxi dispatch - Spanish
31.2400 MHz FM [CSQ] Paging - POCSAG
31.3250 MHz FM [CSQ] French traffic control system data link 31.325 MHz
31.5000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.5 MHz
31.6875 MHz FM [CSQ] French traffic control system data link
31.7250 MHz FM [CSQ] UK on-site hospital pagers - POCSAG. Not sure if these are false decodes or not, but the 31 MHz UK pagers specifically show numerous CTCSS tones. Could be a way of reusing the frequencies. On 31.725 MHz I decoded the following tones: 100.0 Hz, 156.7 Hz, 186.2 Hz, 192.8 Hz, 196.6 Hz, 203.5 Hz, 254.1 Hz.
31.7500 MHz FM [CSQ] UK on-site hospital pagers - POCSAG. Not sure if these are false decodes or not, but the 31 MHz UK pagers specifically show numerous CTCSS tones. Could be a way of reusing the frequencies. On 31.750 MHz I decoded the following tones: 118.8 Hz, 131.8 Hz, 151.4 Hz, 156.7 Hz, 162.2 Hz, 167.9 Hz, 186.2 Hz, 203.5 Hz, 250.3 Hz, 254.1 Hz.
31.7750 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.775 MHz
31.7750 MHz FM [CSQ] POCSAG paging signals - UK hospital pagers. Not sure if these are false decodes or not, but the 31 MHz UK pagers specifically show numerous CTCSS tones. Could be a way of reusing the frequencies. On 31.775 MHz I decoded the following tones: 107.2 Hz, 146.2 Hz, 156.7 Hz, 159.8 Hz, 167.9 Hz, 179.9 Hz, 203.5 Hz, 241.8 Hz, 250.3 Hz, 254.1 Hz.
31.8000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.8 MHz
31.9000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 31.9 MHz
31.9750 MHz FM [CSQ] French traffic control system data link
32.0000 MHz FM [CSQ] Data, probably fishing fleet radio network related
32.0500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 32.05 MHz
32.1800 MHz FM [77.0 Hz PL] Taxi dispatch, Spanish (Costa Rica)
32.1800 MHz FM [141.3 Hz PL] Taxi dispatch, Spanish (Costa Rica)
32.2000 MHz FM [CSQ] Fishery radio Asian fishermen radio chatter 32.2 MHz FM
32.7000 MHz FM [CSQ] Fishery radio, weak Asian fishing fleet radio 32.700 MHz
32.7600 MHz FM [74.4 Hz PL] Spanish, maybe a taxi? Poor conditions very rough copy
32.9400 MHz FM [77.0 Hz PL] Taxi dispatch, Spanish (Costa Rica)
32.9400 MHz FM [141.3 Hz PL] Taxi dispatch, Spanish (Costa Rica)
33.0000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 33.000 MHz
33.0000 MHz FM [CSQ] Data signal, similar to signal heard on 30.5 MHz
33.7500 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 33.75 MHz
33.7500 MHz FM [CSQ] Data bursts, short bursts - previously monitored on this frequency during similar band openings
33.9000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 33.9 MHz
35.0000 MHz FM [CSQ] Fishery radio Asian fishing fleet comms 35.000MHz
35.0400 MHz FM [77.0 Hz PL] Keyup, no voice noted (itinerant frequency)
35.0400 MHz FM [85.4 Hz PL] Spanish (itinerant frequency)
35.1800 MHz FM [162.2 Hz PL] Vernola’s Towing
35.2375 MHz FM [123.0 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.4000 MHz FM [91.5 Hz PL] Unmodulated FM carrier
35.5000 MHz FM [CSQ] Paging - POCSAG
35.5400 MHz FM [CSQ] Paging - POCSAG
35.5500 MHz FM [110.9 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.5500 MHz FM [CSQ] Paging
35.5750 MHz FM [114.8 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.5800 MHz FM [CSQ] Paging
35.6250 MHz FM [123.0 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.6375 MHz FM [127.3 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.6600 MHz FM [CSQ] Data, heavy fading
35.7000 MHz FM [150.0 Hz PL] Decoded as 151.4 Hz - unknown military
35.7125 MHz FM [110.9 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.7400 MHz FM [CSQ] Paging or data? weak
35.7625 MHz FM [114.8 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.8375 MHz FM [110.9 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.8375 MHz FM [136.5 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.9000 MHz FM [123.0 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.9125 MHz FM [110.9 Hz PL] French Autoroute LMR network - with selcall tone bursts
35.9625 MHz FM [110.9 Hz PL] French Autoroute LMR network - with selcall tone bursts
36.0500 MHz FM [118.8 Hz PL] French Autoroute LMR network - with selcall tone bursts
36.1000 MHz FM [118.8 Hz PL] French Autoroute LMR network - with selcall tone bursts
36.2500 MHz FM [CSQ] Strong rapid bursts - data or paging
36.5000 MHz FM [74.4 Hz PL] Taxi, Spanish
36.6000 MHz FM [CSQ - maybe] very weak FM signal, could be the YSD beacon, or something else given the band conditions
37.1200 MHz FM [74.4 Hz PL] Data, SCADA
38.2500 MHz FM [CSQ] Data bursts
38.6600 MHz FM [173.8 Hz PL] Taxi dispatcher, Spanish
38.9000 MHz FM [150.0 Hz PL] Range control - military - decoded as 151.4 PL
39.0600 MHz FM [118.8 Hz PL] Possibly a malfunctioning transmitter, heavy hum heard
39.1200 MHz FM [136.5 Hz PL] Possibly local, Virginia Department of Corrections (DOC) statewide lowband (39.120 MHz 136.5 PL, 39.500 MHz 136.5 PL and 39.540 MHz CSQ)
39.3400 MHz FM [162.2 Hz PL] Highway Patrol - likely CHP
39.3600 MHz FM [162.2 Hz PL] Highway patrol
39.4600 MHz FM [156.7 Hz PL] LLAW1 - Mutual Aid / Interoperability Frequency, radio checks, strong signals - possible repeater (input: 45.86 MHz)
40.1300 MHz FM [CSQ] Strong FSK data - could be 40.125 MHz?
40.3000 MHz FM [150.0 Hz PL] “Base 2, loud and clear, over” - decoded as 151.4 Hz
40.6700 MHz FM [CSQ] SNOTEL - some fading
41.0000 MHz FM [150.0 Hz PL] Decoded as 151.4 Hz - mic key up heard
41.7000 MHz FM [150.0 Hz PL] UNID military, decoded as 151.4 Hz PL
42.1600 MHz FM [131.8 Hz PL] Highway patrol or state police
43.0000 MHz FM [94.8 Hz PL] Unknown business user?
43.0400 MHz FM [114 DCS] Paving or construction - itinerant frequency
44.9400 MHz FM [186.2 Hz PL] Highway patrol dispatch
45.2000 MHz FM [127.3 Hz PL] UNID public safety user?
45.7600 MHz FM [77.0 Hz PL] Virginia Department of Transportation VDOT Channel 25 (truck to truck simplex), heard mobiles ID callsign KA2696
47.2200 MHz FM [110.9 Hz PL] Virginia Department of Transportation VDOT repeater
47.3000 MHz FM [110.9 Hz PL] Virginia Department of Transportation VDOT repeater
47.3000 MHz FM [114.8 Hz PL] Virginia Department of Transportation VDOT repeater
47.3000 MHz FM [123.0 Hz PL] Data bursts - likely part of VDOT’s system
47.3400 MHz FM [110.9 Hz PL] Virginia Department of Transportation VDOT repeater
48.1000 MHz FM [114.8 Hz PL] Radio checks, could be local (local-ish?) - Dominion Energy (Dominion Virginia Power)
49.4200 MHz FM [67.0 Hz PL] Pike Electric - truck to truck comms
49.5000 MHz FM [67.0 Hz PL] Pike Electric - truck to truck comms
kkn50
Long Time Member
South Texas Logs
39.3400 162.2 CA HP
40.6000 150.0 US MIL - Helos
44.9400 186.2 CA HP
45.5000 192.8 CA HP
KF4ZTO
29.779 mhz very weak RTTY much noise here unkown who it is. Tons of noise here making it very hard to listen.
26.375 mhz freebanders heavy noise many stations spanish beeps ect.
All heard 5-5-2023 Angelo
29.779 MHz (or 29.780 MHz) is home to several FSK / RTTY data signals that seem to pop up pretty often during band openings. They’re likely not originating from the U.S.. They could be Datawell Waverider data buoys (which operate on numerous frequencies in the 25-40 MHz range).
W8HDU
Lima, Ohio
Unusual comm this morning. (Edit: Sunday, 7 May 2023 @ 10:06 Eastern). Way down in noise with heavy fades, 29.7300 pl-123.0 "Hey, Kevin, I'll switch trucks and meet ..... (heavy fade) .... and go from there." Other station, (presumably who he was talking to), was way to weak to make out any words. Second transmission ".... taking 203 as 219 is out of service." Whole exchange was about a minute and a half. Will be watching for this again.
KF4ZTO
29.7300 MHz FM 123.0 Hz PL.
I honestly believe there are a lot more users of the 29.710 MHz FM, 29.730 MHz FM, 29.750 MHz FM, 29.770 MHz FM and 29.790 MHz FM land mobile (Part 90) frequencies in the U.S. than there are licensed users in the USA. I’m sure there’s a lot of business band users with expired licenses that just don’t know any better. I know of a couple business users local to me that are operating on VHF low band under expired licenses (truck to truck comms, ready mix concrete, 43 MHz band).
That’s not to say what you heard on 29.73 MHz wasn’t licensed. It just seems like that little sliver of spectrum 29.7 MHz to 30.000 MHz has a lot more activity than meets the eye. There’s POCSAG paging systems every 50 kHz from 29.75 MHz to 29.95 MHz (I think they’re somewhere in/near Europe), there’s unexplained data signals, the fishery radio systems / fishing fleets, Canadian paging, and of course there’s the out of band CB operators/freebanders.
29.750 MHz, 29.800 MHz, 29.850 MHz and 29.900 MHz are some of the frequencies I routinely check for paging activity as part of a check to see if the band is open to Europe.
As far as logs go:
32.940 MHz active right now (1631 local eastern time). YL dispatcher “in the park, in the park” [pause] A02” “A02”
W8HDU
Lima, Ohio
Well I know of one licensed user. But I will concede there are probably more unlicensed on the frequencies. Some are just freebanders.
Some are preppers and survivalists who use 25-31 for comms (discretely). Very rare to hear them speak. They also operate packet, which I logged in Upper Michigan at 10:22PM, Friday, April 10, 2020, on 26.312500 MHz, narrow band FM. Good enough to copy his/her traffic.
There is one station I've yet to ID which operated on 29.740, 29.750, or 29.760. "I believe" his ops are in the south as I've heard him mention highways, and names unique to KY, TN, and GA. It sounds like he may be a car carrier for hire. He's been a mystery for at least 8 years.
