2023 VHF Low Band Logs
pro2004
SE Ontario Canada
1700-1930 hrs EST into Eastern ONT.
41.80 150.0 safe flight
44.58 BNSF data packets
45.98 AL prison morse id
46.10 PL 123.0 fire Rescue 14
46.46 Rockingham CO NC. Med call for Stn 120 Laser st and Lois Lane and 2nd for Engine 55 - Madison fire
46.75 150.0
46.95 150.0
47.02 pl 107.2 partial morse id ending in 66?
47.16 PL 107.2
47.925 150.0 voice and 20KHZ data bursts
49.52 PL 127.3 - utilities?
  • Like
Reactions: 217
217
Sporadic E enthusiast
North Carolina
Any thoughts to the roughly 1,500 hz tone in the reception? The het "appears" be be Barnstable dispatch's transmitter beating against either another (continuous) transmission on the frequency, or a birdy within the scanner.
Great catch! Thanks for posting the audio.
It is in the system, some sort of alarm, they can turn it on/off. I hear something similar in my locale when a dispatcher goes into emergency traffic only on channel. I'm not sure what frequency they are testing but I do receive it on 33.700 at 9 am. Dukes county and Nantucket have no FCC license for low band that can find.
North Carolina
33.780 mhz 22:40 utc-22:50 utc 5-31-2023 FD male dispatcher call for engine company 18 and engine company 28 for fire alarm.Female dispatcher in there to.Weak noisey .Page went off male dispatcher gave call for truck company 3. Fair amount of traffic im hearing. Angelo :)
33.780; Southwestern NH District Fire Mutual Aid in Keene NH will almost always say KCF415 and time stamp at the end of transmission. KCF415 would be my vote for the best sounding system. Provincetown fire in Provincetown, MA usually say Provincetown fire at the beginning of transmission, then at the end you here it cut off, something to do with the digital they use, then a slight pause after that. It is so noisy at times I lock it out. Provincetown would be my vote for the worst.
marvinsuggs
Richmond, TX
Could be Falmouth, MA or SW New Hampshire Dist Fire Mutual Aid.
marvinsuggs
Richmond, TX
46.75 150.0
46.95 150.0
47.16 PL 107.2
46.10 Citrus Co, FL FD
47.02 New York DOT
47.16 NC DOT
  • Like
Reactions: 217
sprman1955
Lavergne ,TN
33.660 page/tones
33.580 male dispatcher
33.860 with engine 3 call
33.880 with fire call
33.900 female dispatch with call for engine 3 to a building fire alarm.
Help idenifiy these for me all heard 6-1-2023 at 20:00utc to 20:23utc here in tn on a pro 2006 ,discone ant in the attic thanks.Band seems to be open some were very strong here.Angelo
marvinsuggs
Richmond, TX
33.660 page/tones
33.86 is probably Washington Co, MD FD
33.90 Quinebaug Valley, CT FD
marvinsuggs
Richmond, TX
May 2023 Richmond,TX Bearcat BCT15X scanner Sirio GPA 27-45 MHz ground plane antenna.
31.10 Asian fishermen
31.20 203.5 Taxis, Alajuela, Costa Rica
33.86 77.0 Washington Co, MD FD
33.86 146.2 ?”343 clear 1801”
33.88 82.5 Licking Co, OH FD
35.18 179.9 ? Terrys down there too
37.10 162.2 Morgantown, WV Utility Board
37.36 110.9 Illinois Dept of Corrections
37.58 D412 ?cw id
39.50 131.8 Bland Co, VA SO
39.52 79.7 Craig Co, VA SO
39.98 88.5 Holland, MA Public Works
42.06 203.5 Missouri DPS/Springfield
42.56 173.8 Caswell Co, NC DOC
42.92 203.5 Missouri DPS/Lee’s Summit
42.94 173.8 Missouri DPS/ Poplar Bluff
43.04 107.2 Kinney Contractors, Statewide IL
43.28 77.0 Ingram Readymix/Houston, TX
43.32 192.8 ?
43.44 77.0 Ingram Readymix, Houston,TX
43.54 165.5 music
43.54 146.2music
43.54 196.6 music
43.56 CSQ? Music
43.88 146.2 ? Come to our gravel pond load chucks truck
44.58 CSQ BNSF Hy-Rail Compliance System
44.58 D412 ? The time is 12pm Monday may 29th
45.48 162.2 Pompton Lakes, NJ FD
45.88 206.5 ?
45.92 151.4 Westvaco Rescue Sq/ Covington Co, VA
46.00 D251 Oconomomac Transport , Waukesha Co, WI
46.04 107.2 Randolph Co, VA EMS
46.06 97.4 Cumberland Co, PA FD
46.10 123.0 Citrus Co, FL FD
46.10 D205 ? “Route 119 and route 250 bypass”
46.12 71.9 Tyler Co, WV FD
46.12 79.7 ? “483” 49 back at base
46.14 103.5 Harrison Co, WV FD
46.14 136.5 ? Cross arms have been hit they should be Enroute
46.18 186.2 Adams Co, PA FD
46.18 192.8 Appomattox Co, VA FD
46.46 CSQ Baltimore Co, MD FD
46.50 123.0 Putnam Co, NY FD
46.50 141.3 Yonkers, NY FD
47.02 100.0 ? Cw id
47.04 91.5 ?
47.06 D073 Florida DOT, Deland
47.12 D346 Florida DOT, Miami
47.12 D664 Florida DOT, Tallahassee
47.18 D134 Florida DOT, Lake City
47.32 107.2 New York DOT, Hamilton Co
47.38 D143 Florida DOT, Fort Lauderdale
47.40 D134 Florida DOT, Lake City
47.56 136.5 Shoosmith Bros, Chesterfield Co, VA
49.52 67.0 Pike Electric 1, Nationwide
49.52 127.3 ?
49.58 67.0 Pike Electric 3, Nationwide
Sent from my iPhone
marvinsuggs
Richmond, TX
37.58 D412 ?cw id
43.32 192.8 ?
43.54 165.5 music
43.54 146.2music
43.54 196.6 music
43.56 CSQ? Music
45.88 206.5 ?
47.02 100.0 ? Cw id
47.04 91.5 ?
49.52 127.3 ?
Sent from my iPhone
I've identified 46.10 D205 Barbour Co, WV FD
217
North Carolina
June 1st
I was trying to get some video of CITO tv 3 from Timmins, Ontario, Canada. That didn't happen as 6pm station tests were about to begin.
33.900, 33.560 - Lancaster county PA. Database states LC will stop using the low band January 5th, 2021. 33.900 is the tone outs and addresses. LC is an easy one to ID nowadays as they use the word 'medic' and you can definitely hear the P25. Dispatchers with some chatter on 33.560. Darn CB was in there too.
Lancaster county
46.460 - Suffolk County NY. The database says they will be moving off of Low Band shoon. They haven't moved yet. Dispatch for Halesite and some tests including Montauk? tower and Wading River.
Suffolk county
33.780 - Falmouth, Barnstable county, MA. The Barnstable County Sheriff’s Office operates an Emergency Communications Center located on Joint Base Cape Cod which is responsible for the dispatch of emergency 911 calls for many municipalities across Cape Cod. The towns of Falmouth, Mashpee, Harwich, Chatham, Brewster, Orleans and Wellfleet, the Mashpee Wampanoag Tribe, and Joint Base Cape Cod.
Falmouth
33.580 - KNCS289 - Yarmouth Fire Dept Dispatch, Yarmouth, Barnstable county, MA. Yarmouth Fire Department served as the County Mutual Aid Center from the time of inception until November 3, 1991 when it was moved to the Barnstable Sheriff's Dept.
Yarmouth
33.780 - Barnstable county, MA.
Barnstable
46.260 - KED281 - 60-Control, Dispatcher -679-, Westchester co. NY. Fairview Fire Dept. White Plains, NY and
Hartsdale Fire Dept. Hartsdale, NY. "60 Control" provides primary dispatch services for 52 fire departments and 32 EMS agencies.
60-Control Westchester
KNIP458 - 33.560 - Easton, CT. Thanks for the call sign.
Easton CT
Delaware county, PA, Speed talker.
Delaware co.
217
North Carolina
6/2/23
33.780 SWNH District Fire Mutual Aid dispatch center in Keene NH. KCF415 Fire-EMS dispatch covering mutual aid in three New England states (MA, NH, VT). One of the largest of its kind in North America.
Several lightning strikes in the Southwestern New Hampshire District Fire Mutual Aid region and a tower was hit. Dispatch-415 with a 2 alarm fire. Received in North Carolina.
Dispatch-415
Motorola90
Ocean County, New Jersey
6/2/23
Dispatch-415
That a very professional dispatch center!
