No, before we added nxdn firmware, the 436 decoded these 3 sites 100% error free. Plus had another person running dsd+ on the same said systems and none of the errant tg or uid exist. When using the toggle left / right on the vol knob in the midst of the conversations, it would then display the correct tg and uid info till the next user keys up. These are all cap+ dmr systems.
Sent from my SM-G935V using Tapatalk
I doubt its due to a hardware issue in only some scanners. It's more likely to be an oddball configuration on some systems, or a side effect of RAS, which makes error correction impossible on systems that use it. Weak signal + RAS is going to have erroneous TG and unit IDs, and there's little that can be done to fix that.
