Happy BUFF Day 03-15-11
Hello all,
Was out running errands today from around 1pm to 4pm. Never heard any of the aircraft below while in the car. I do have a scanner in the car, but with running in & out of stores, I missed it all. Fortunately I did have a scanner at home being recorded. Was really bummed out when I started listening to the recording, & realizing what I had missed today. Well at least I did get to hear what I missed. ;~)
03-15-11
From ProScan recording BC780XLT # 1.
DUECE 03 w/ SKULL 22 (Barksdale BD B-52’s)
254.350 Chi.C. 13:16:57pm. (01:16pm).
336.400 MN.C. Center DUECE 03 flt of 2 heavies non standard 260 to 270. Confirm we’re cleared, GARLAND GANTLET & PIKE ATCAA’s. 13:17:54pm, to 13:21:33pm EDT.
266.600 R-4201 STEELGATE Control, 6TFQ910070. DUECE copies, 1253 N44.50.819 W084.35.107 N44.51.401 W084.34.5870. 1253 beep 2 weapons. SKULL withheld ?? for TOT for GBU12. HIGH FOX, SKULL 22 flight we’re also going to have to RTB. SKULL flight, SKULL flight go Juliet in front. 14:01:31pm, to 16:23:36pm.
269.4500 MN.C. Non standard formation 3 mile trail. 3075 with the flash for SKULL for DUECE. Try to find our flight plan. 03 flight, copies cleared BAD, via dir FDY, flight level 250 block 260. Next point MRB 346, 012, next point, EIC, the final point BAD, how copy. DUECE 03 is in formation with SKULL 22. 15:12:53pm, to 15:23:32pm.
269.525 Cleve.C. Center DUECE 03 flight of 2 heavies non standard formation within 3 (Miles) in the block 250 to 260. 14:22:53pm, to 16:10:02pm.
UNK?
311.000 Qty Reno? 25 on the gas. Pilot co-pilot, window heat. Sounds like a C-130. 13:27:20pm to 13:59:58pm.
CG6592 (HH-65)
225.400 MTC twr, departure from the west ramp at your own risk, wind is 080 @ 8, 01:28pm ish.
345.000 Detroit Air, 01:42pm.
RAMA 42 (Ellsworth EL B-1)
269.525 Cleve.C. Center RAMA 42, 240. RAMA 42 switching to 254.35. 14:22:53pm. to 16:10:02pm,
254.350 Chi.C. RAMA 42 dir Ellsworth, 15:06:47pm. (03:06pm).
CHILL 21 also says 32 flight x 2
269.525 Cleve.C. Flight check, 2, 3, 230 21 flight. Say again the frequency for CHILL 32 flight,
CHILL 21 flight. X 2 (Minot MT B-52's)
281.475 Cleve.C. CHILL 21 flight check. Go for CHILL 21. We’ll ah execute a flight split up but for the most part we will be a formation. This will be the southern most point of the route, will be heading back north. 260 check, 2. Elwood City flight plan route. 2 B-52’s Sir. 285.625 CHILL 21 flight push. 15:20:08pm, to 15:44:38pm.
285.625 Cleve.C. Standard formation within 3 miles 250 block 260 check 2. 100 for 036 req extend 10 miles to the west of that point and then flight plan route. 15:32:20pm, to 15:55:33pm.
338.300 MN.C. 250 230 waiting for a response from our wingman. CHILL 21 flight 220 block 230. Go Golf? 16:11:43pm, to 16:13:23pm.
266.600 R-4201 STEELGATE Control, CHILL 21 flt can you verify that with pilots ?? 16:23pm.
STING 31 x 2 (TOL F-16's)
139.625 V 06 Trouble shooting a brake problem. Good brake power for all 4 channels. Burn down some gas. Look over at your wing tips. Do you have any icing? No AOA reading?
348.750 Cleve.C. 240 in order to burn down some gas. Like to stay in the clear if possible. Toledo burning down some gas. Cautionary heading back. 14:29:02pm, to 14:34:12pm.
251.125 Cleve.C. Sting 31 in the climb 23 for 250. Center Sting 31 like to climb up to 260 if able. Request 270. Flight of 2 we’re going to be holding over Toledo for a little while going to have 2 with me. Sting 31 begin our descent down in for ILS 7 in Toledo. 270 for 11 thousand. Thanks for the help push BTN 4, 14:35:04pm, to 14:40:23pm.
317.550 TOL app, emergency in the descent 180 to 8000 270 assigned. Looking for the ILS 7. It will actually be Sting 32 landing first. Like to coordinate for Sting 31 clearance back around. 14:57pm. (02:57pm)
STING 33 (TOL F-16)
282.700 AR-632 Secondary, 14:32pm. (02:42pm)
238.900 AR-632 Prime, 73 STING 33 on 238.9 how do you hear? 14:34:38pm, to 14:37:53pm.
282.500 AR-Primary, & ACM, Sting you guys up AR Primary? (Cleared) Astern. (Cleared to) Contact, step back & reset your system. STING 33 DARKSTAR picture single hostile group Bullseye 079 (Bearing) 14 (Range/Miles) 17000ft (Altitude) maneuver, single contact Bogey. 14:34:52pm, to 15:03:32pm.
