ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
enosjones
Price, Utah
It should be exactly like the scanner favorites_lists folder contents. No txt files at all.
I'm looking to see if I had previously purchased a Proscan license, I tried to enter my info and it said it was already taken, is there a way you can look and see if I had one? I can't msg you so I had to msg it here, sorry
Sent from my iPod touch using Tapatalk
ProScan
Software Provider
Ontario, Calif.
All key issues are handled by email. Provide email address used time of purchase or other other identifiable info. Provide the Name you are trying to enter.
support@proscan.org
rwier
Phoenix, AZ
Yahoo!!! Used basically ALL the hints from the helpers!!! Got my primary HP-1 FL (have about 22 FLs total) into ProScan. Took a screen grab. Sweet!!!
WX4JCW
Stow, Ohio
downloaded it and testing now :) very nice
-------------------------------------------- Edit for suggestion--------------------------------------------
on the headers for the channels (not sure elsewhere yet) it would be nice to be able to select multiple channels and make changes to things like delay and color/alerts etc etc
ProScan
Software Provider
Ontario, Calif.
Thanks, I'll look into it. The Find & Replace will do the same thing but this way may be quicker for a few rows.
WX4JCW
Stow, Ohio
find and replace is nice but if importing from RR its difficult to assign color codes and such to 100+ channels im a special case as i travel all lower 48 constantly using the built in DB but when i am staying for a time i make my own custom lists
ProScan
Software Provider
Ontario, Calif.
It's already figured out. Will be in next version. It will be like this.
1. Click on a column to change.
2. Select the rows to change.
2. Right Click and click on Replace.
2. All selected rows column will change values to the first row selected.
ProScan
Software Provider
Ontario, Calif.
It's finished. email me if you want the latest.
n3ouc
Macungie, PA
Bob,
I am now using the latest and I really love where this is going. I have only one issue and that is when you download from the RR database, the service type for everything defaults to Custom 1. I have tried find and replace but it does not seem to be usable for service types. Takes forever to change manually as copy and paste doesn't seem to be an option either. Otherwise, a great addition to an already great program.
Mike
ProScan
Software Provider
Ontario, Calif.
Bob,
Mike
All the channels will show as Custom1 when importing from the RRDB as the scanner uses the same default when adding channels. I see the RRDB API has a "fccRadioServiceCode" I'll look into that to see if it's useful and a correlation with the BCDx36HP "Service Type" so the Service Type can reflect the RRDB when importing.
Find & Replace does work. Be sure you're selecting the right type of channel to search; conv. freq or TGID. and "Where To Find" is set correctly.
WX4JCW had a great suggestion with replacing values in cells, I put it in right away and I'm going to put it in the DMA and Non-DMA database too.
It works like this:
1. Select a cell containing the value to copy from.
2. Hold down the shift or control key and left click the other cells to copy to.
3. Right Click and click on "Replace Values In Selected Cells With First Selected Cell".
Here is the link to the new file. It's a exe file only. Unzip and copy the exe file over the original exe file.
http://www.proscan.org/ProScan.zip
GTR8000
NY/NJ Database Guy
BEE00
I believe you want the tags element, which would return the Service Type for both conventional frequencies and trunked talkgroups (as it's known by Uniden, otherwise known as the Function Tag in the RRDB)
ProScan
Software Provider
Ontario, Calif.
Got it figured out. It turned out the numeric codes are exactly the same as the scanner file format so no conversion was needed.
