ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
JLM7424
Williston,ND - Williams county
Hello while monitoring/ logging 2 scanners a SDS100 & 536hp same frequency Same Antenna I get two very different RSSI readings
All settings in Proscan look the same any Idea why this would be .
SDS100 RSSI: -40
BCD536hp RSSI: 414
Moose
New Jersey
Having a an issue with Proscan recordings as viewed on the BCD536HP Proscan scanner display. After so many seconds a recording will "reset" itself and start recording again. I was recording a milair frequency and it had reached somewhere around 45 seconds. When I looked again the initial recording was gone and a new one was in its place showing a new start time and showing about 8 seconds of recording. On my C:\ drive in the Proscan\Recordings folder all the original transmissions are still there and playable. Did I change something inadvertently? Thanks
Moose
New Jersey
Having a an issue with Proscan recordings as viewed on the BCD536HP Proscan scanner display. After so many seconds a recording will "reset" itself and start recording again. I was recording a milair frequency and it had reached somewhere around 45 seconds. When I looked again the initial recording was gone and a new one was in its place showing a new start time and showing about 8 seconds of recording. On my C:\ drive in the Proscan\Recordings folder all the original transmissions are still there and playable. Did I change something inadvertently? Thanks[/QUOTE
I was able to watch when it happened again. As soon as the recording hit 1 minute it disappeared. Then popped up again as a new recording. I have "Active row in view" set. "Activity" is set. In the Options tab I see that Delete < 2sec is checked. Max recording time is set to "none". Recordings auto delete is set at 30 days.
ProScan
Software Provider
Ontario, Calif.
Does it only happen on one channel?
Did it just start happening?
Does it do it at the one minute mark each time?
Try setting the Max. Recording option to some value and back to None.
I haven't heard of this before and don't know what would cause this.
kennyblues
Randolph, MA
Monitoring a VHF P-25 channel with a 2 digit NAC. I can't get Proscan to log the NAC, no problem with 3 digit NAC's only the 2 digit, either in a NAC search or a programmed NAC.
Any thoughts? Anyone else?
scan-pa
RRDB Admin
Lebanon, Pa.
What is the user, frequency and nac?
Sent from my SM-G935V using Tapatalk
jackkd4vrd
Bolivia, NC
2nd key purchased
HI Bob,
Keep up the good work!
Your dedication has influenced me to buy another scanner and move back to Uniden so I can use your software.
Thanks again!
Jack
KD4VRD
FraserBonnett
Harrisburg, PA
Hi Bob, a feature request
I'm using 4 BCT15X's to scan Mil Air using a Custom Search broken up into four segments. During the search I can lockout local known frequencies while I search for new hits. I know I can pre-enter Lockout frequencies but it appears to be a manual entry process and there are +400 I would like to add:(
Could the "Get Clipboard" functionality be added to the lockout frequencies?
N9PBD
Southern Illinois (Metro St. Louis)
A couple questions: What type of scanner are you using? Can you use tone/NAC search, rather than trying to enter a two-digit NAC?
What system, if you don't mind me asking? NAC is supposed to be a 12-bit (3 hex digit) value, not two digits.
kennyblues
Randolph, MA
Using a 996XT, latest firmware, latest Proscan update.
It is programmed twice, once with the $70 NAC entered, once programmed as digital, NAC Search.
The frequency is 169.5750
N9PBD
That narrows the field somewhat, but I haven't found any reference anywhere for a $70 NAC for a Federal frequency. Was that NAC published, or discovered during a search? Have you tried NAC $070? $070 is a valid FBI NAC.
ProScan
Software Provider
Ontario, Calif.
What's the NAC shown on the scanner display? Can you look at the scanner returned data to ProScan and see what it looks like.
ProScan
Software Provider
Ontario, Calif.
The scanner displays NAC 70
Not sure where I can find the scanner returned data.
I don't see that in the Tests and extras tab
It should be in the Test & Extra tab. If the data moves too fast, you can always turn on the Scanner Data To Scanner Data.txt File option located in the General Options area. Send me the file.
