ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Hey all, hoping someone can help me figure this out. I'm using ProScan with my BCD536HP. Washington State Patrol (District 2 Bellevue Dispacth) every so often creates a new entry in my transmission log, and I can't figure out why. The frequency, etc., all appears to be the same so not sure why ProScan keeps making new entries. Not sure if ProScan is getting confused or if the scanner is sending something different every so often that isn't reflected in the table.
Pic attached.
Thanks!
-Lou
It should be one entry for the conv. frequency and NAC. I'll check it out before the next release.
ProScan
Software Provider
Ontario, Calif.
Bob, When I play back the MP3 recordings, in the Recorder. I can't hear anything, sometimes. Other times I can. I checked to see if it was muted, it isn't.
Check if the problem is on the recorder side or playback side. If you can playback files using the File Explorer then the problem is on the playback side so I would check the OS settings . This thread should help.
ProScan may show grayed out when not playing an audio recording in ProScan. Select a file that is long enough so you will have time to call up the sound settings.
bossco
Moscow
FYI
Hello. Faced with an interface bug - while pressing the Func button, one of the function keys turns into abracadabra. (Interface for scanner Uniden DSD100/200)
Reconrider
Inside the Galaxy
Radio Galaxy
Do
FYI
you have the correct scanner set under “scanner type” menu button up at the top?
bossco
Moscow
Do you have the correct scanner set under “scanner type” menu button up at the top?
Yes, correct scanner type - maybe the inscription on the button is big?
PS
Watching this on my laptop (1080p) Windows 10 Home. Also on my PC (4K) Windows 10 Home.
ProScan
Software Provider
Ontario, Calif.
PS
The text in that button should be the same as the ProScan display and scanner display soft key 1. The soft key 1 on the ProScan display is blank. It should show "Close Call" just like it's shown on the scanner display. I can't duplicate the problem so if you can email me the Sentinel profile file, I can see what's happening.
Chris0516
Pittsboro, North Carolina
I tried that. It isn't a 'global' problem. It seems like, it is intermittent. The OS sound is fine.
ProScan
Software Provider
Ontario, Calif.
Software doesn't cause truly intermittent problems. Software is based on logic and makes decisions based on a set of conditions. Cables and hardware can cause intermittents.
Try to determine if the problem is on the recorder side or playback side. Is it the same channels each time? If it is then perhaps the channel in the database Record box is not checked or if it's a certain system then check the system in the database that the Record box is set to All Channels or Marked Channels.
Chris0516
Agreed
MichaelC34
Boston, MA
If i want to make a few changes to some of my groups with the channels and upload (update) that to the scanner would I just choose the Upload configuration button and check off the ones im making changes to?
ProScan
Software Provider
Ontario, Calif.
If you're making changes and not adding or removing items then an easy way to upload the changes is by selecting the nodes in the tree then right click and click on "Upload Selected Nodes"
If you're using the Upload method, make sure the "Upload Systems" box is checked.
