ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
curtisdevault
Bozeman, MT
I have been trying to implement an SRV record on the domain name that I use to access my ProScan server. Hoping you all have some guidance as to why I cannot get it to work.
I can get to the web server using mydomain.com: port (ignore the space, kept turning it into :p), my goal is to be able to go to scanner.mydomain.com and have it go to the ProScan web server page without specifying the port.
I created a CNAME for scanner.mydomain.com. Then created the following SRV record:
_proscan._tcp.scanner.mydomain.com 0 0 port dynamicdnsprovider.com.
I have also tried:
_proscan._tcp.scanner.mydomain.com 0 0 port mydomain.com.
Does anybody have any thoughts? I have confirmed using nmap that it is a TCP port, but I wonder if there are only certain services that are allowed to be used int he service name part (_proscan)? Does anybody have any thoughts? I have gone down so many Google rabbit holes trying to come up with a solution.
Thanks!
belvdr
I can get to the web server using mydomain.com:port, my goal is to be able to go to scanner.mydomain.com and have it go to the ProScan web server page without specifying the port.
I have also tried:
Thanks!
I have experimented with what you're trying and always fell short. Why not change the port forward, so that port 80 goes to the port of your ProScan web service?
belvdr
Correct. Per the manual and release notes:
Works with imported RRDB (RadioReference DataBase) systems on version 21 and above.
Hi Bob, is there a way to sync a current FL with the RRDB? For instance, I have a P25 system here split into several FLs, and picking and choosing the TGIDs for each one via re-import is going to be a chore.
belvdr
On further review, you can disregard my request. The feature is a great idea, but it's not quite mature yet. I did the following and many "RRDB Differences" disappeared:
  1. In ProScan, import from RR
  2. Write to the device - I used FTP write
  3. In Sentinel, read the scanner. In my case, I deleted everything in Sentinel prior to reading.
  4. In Sentinel, write to the scanner, and select erase all FLs.
  5. In ProScan, do an FTP read.
Another anomaly is if frequencies or TGs are added at separate times, it duplicates the system name. Moving anything results in ProScan suggesting it be deleted.
Chris0516
Pittsboro, North Carolina
Bob, I have been trying to do some editing in Proscan. :cautious: I was able to arrange FLs' last week. When I only had my 436HP.:) I got my Christmas present really early this year.:) My parents'(w/ my $ help), bought me the SDS100.:D The problem is, even after pouring through the Proscan Manual, thread searches in this RR forum, and using Google.:(I can't find how to re-order FLs' via Proscan. The main FL, and inside a FL. :confused:
(hiding in a corner)
ProScan
Software Provider
Ontario, Calif.
Just click on a FL node to highlight it then then drag it to the desired location with your mouse.
"inside a FL" If that means system. department, site, or channel nodes then you can reorder them just like the FL nodes
Chris0516
I tried 'drag n drop'. While logical, that didn't work. What I am thinking of is, a tool in PROSCAN, where. A sort can be done via an 'up' arrow and 'down' arrow.
ProScan
Software Provider
Ontario, Calif.
It works. Try it this way.
1. Click a FL node to highlight it.
2. Move the cursor over the highlighted node.
3. Hold down the left mouse button and move the mouse to were you want the FL node positioned then release the left button.
rgchristy
Delco, PA
I'm trying to document a new MotoTRBO system in our area and would like to learn how to program it into my SDS100, using ProScan.
I've searched this thread, the Easier to Read manual, and the Uniden Twiki page.
In this thread, SDS200: - LCN Finder on MotoTRBO Trunk message #3 describes how to do it in Sentinel, but I'm not sure if it is the same.
All I know so far, is that it is a CAP+ system, the two frequencies and their color codes.
The first question is, can it be done with this limited amount of information?
Can I start the process with my SDS100 or do I need to set up my RTL-SDR dongle and go that route? I haven't set it up and have no experience with DSDPlus.
Is it the same process as used in Sentinel?
If I don't know the LCNs and I program the system into ProScan, can I use the LCN finder? I didn't know if you need the LCNs in order to program the system into the SDS100 (I know, it sounds like a catch 22).
Any help would be appreciated.
ProScan
Software Provider
Ontario, Calif.
Programming in ProScan is done basically the same way as it's done in Sentinel and at the scanner front panel.
Add a system then add department/s and site/s. Add the TGIDs to the departments and add the frequencies to the sites.
To add a system, click on a Favorite node then click the Add System button (circled in red) then at the Prompt, choose MotoTRBO (like in the 1st image) then click the OK button. The LCNs and Color Codes are set at the frequency level like in the 2nd image.
