ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
vince48
Central Valley, CA.
Greetings,
I have a question regarding recording. I want to record 3 individual conventional frequencies that are not very active. Is it possible to actively scan other frequencies or, do I have to be parked on those frequencies in order to record?
I'm using LAN connection and I have those frequencies I want to record "checked" in the database
belvdr
Greetings,
Your scanner receives the signals and ProScan records them. If the scanner doesn’t receive, due to not being on frequency, then no recording is available.
bravo14
Polk County FL
Had a question on weekly Full Database update for proscan. It's been awhile I used proscan and I forgot to where to update the weekly hpdb full database at.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 22.0 Just Released!
  • Added - BC125AT scanner support.
  • Added - BCD160DN & BCD260DN scanners support. Scanners not out yet as of the date of this release.
  • Many many small improvements
A big thanks to @N9JIG, for lending me his BCD260DN test unit.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
ProScan
Software Provider
Ontario, Calif.
You might be thinking of Sentinel that gets the weekly update from the Uniden server. Since you're a Premium Subscriber, you can import directly from the RRDB into ProScan and not wait for the Uniden (HPDB) weekly update.
Guldnerk
Benton County, IA
ProScan Website
Awesome, I just updated mine. Is there a list of what all of the changes were other than what was listed above?
N9JIG
Sheriff
Moderator
Far NW Valley
Go to the Help Menu in ProScan, and near the bottom of the Table of Contents click on Version History. Bob keeps a log of the changes from version to version there. In there he only lists the updates for the 3 radio models listed above.
dispatcher812
Connecticut
Downloaded and installed this latest update and still cannot update GPS in the Google maps. I do not get the update node option after an adjustment. Got this error when I clicked on Google Maps in the location tab. I installed Proscan on a second computer to see if it was just this one I am using and still had the same issue.
ProScan
Software Provider
Ontario, Calif.
Try using the external browser option and see what happens.
TGuelker
Retired ASE CMAT L1 MRRT
Collinsville, Illinois
OK thanks. I never use edge but that is whats loading. I will look at it. Thanks for the help.
You might want to check out Chris Titus and his Windows debloater. It will remove Microsoft Edge.
ProScan
Software Provider
Ontario, Calif.
.html files probably needs changing to Edge
It's fixed. It will be in the next release. If it still doesn't work then submit a bug Report. Link is on the proscan.org web site.
Kentc
Redmond, WA
Bob, thank you for your great contribution to the community. I know it's extra work and a one-time expense, but have you ever considered signing your exe?
