ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
yes, but still showing not secure when my browser goes to the site.
I have also used my no-ip on my iphone and windows laptop and still giving me unsecure in the web address line
If you use https, does it show secured.
Did you check the 'Redirect HTTP to HTTPS' box? Restart the Web Server after you check the box.
thekoos
I cannot access the ProScan home web page at all on any platform, browser or computer I own. I can access sub pages assuming I know what they are. As an example "ProScan" works just fine. And yes https or not makes not difference...
scottct1
Newington, Connecticut
Getting a 404 here as well.
I like to have my machines reboot once a week, is there any way to have it so when ProScan restarts that it automatically restarts the WebServer and Recording as well?
Thanks!
fxdscon
¯\_(ツ)_/¯
I'm having to replace my computer and trying to re-download Proscan but I get the 404 error page. Have used Chrome and Edge.
Try this link:
Kelita
Tucson, AZ
Try this link:
THANK YOU!!! (y)
ProScan
Software Provider
Ontario, Calif.
Here's the 1st look at the Waterfall support. It's still in alpha but seems to work nicely. I just need to do some work on the y-axis scaling and read the colors from the Sentinel profile.cfg file.
Unzip and copy the files over the originals. Stop ProScan 1st.
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
Works well and pretty smooth with the SDS200 and the USB connection. I expected it might need the LAN connection for the 200 to maximize performance.
Now, I'm going to be "that guy" for a moment (apologies in advance).
Is there any chance, or is it even feasible, that this could develop into a larger screen "point, click, and tune" kind of thing? That would be beyond outstanding.
I realize it's early alpha and I do realize that I can resize the screen when in display only mode.
Thanks for adding this. Lots of potential.
bravo14
Polk County FL
I had a question on Quick Key Status? I was making a local FL and and have some surrounding counties in. Say if I want to select certain QK in proscan I don't have to go on scanner and deselect qk I don't need to scan. Is there something I missed? I looked everywhere for that section.
ProScan
Software Provider
Ontario, Calif.
Correct. Write to the scanner for the changes to take effect. If you want to enable or disable a certain sys/dept./site on the fly then you need to use the scanner keypad. This is from the Sentinel (Easier to Read) BCD436/536HP Manual.
System Quick Keys Status Tab This is where you enable your System Quick Keys. Same function as "Set Scan Selection > Manage Quick Key Status > System Quick Key" in the scanner.
Dept/Site Quick Keys Status Tab
This is where you enable your Department and Site Quick Keys.
