ProScan
Software Provider
Ontario, Calif.
yes, but still showing not secure when my browser goes to the site.
I have also used my no-ip on my iphone and windows laptop and still giving me unsecure in the web address line
If you use https, does it show secured.
Did you check the 'Redirect HTTP to HTTPS' box? Restart the Web Server after you check the box.
ffighter17
Texas
YES IT SAYS TRUE
Sorry about the caps in the last post. I have it showing HTTPS now on my loptop connected through my hotspot on my phone. I am assuming our webfilter at work is blocking it. We are very restricted. Thanks for the input
ProScan
Software Provider
Ontario, Calif.
Is the 'Redirect HTTP to HTTPS' box checked?
thekoos
I cannot access the ProScan home web page at all on any platform, browser or computer I own. I can access sub pages assuming I know what they are. As an example "ProScan" works just fine. And yes https or not makes not difference...
belvdr
Not getting a 404 here, just a blank page.
scottct1
Newington, Connecticut
Getting a 404 here as well.
I like to have my machines reboot once a week, is there any way to have it so when ProScan restarts that it automatically restarts the WebServer and Recording as well?
Thanks!
Kelita
Tucson, AZ
I'm having to replace my computer and trying to re-download Proscan but I get the 404 error page. Have used Chrome and Edge.
fxdscon
¯\_(ツ)_/¯
Try this link:
Kelita
Tucson, AZ
Try this link:
THANK YOU!!! (y)
ProScan
Software Provider
Ontario, Calif.
Here's the 1st look at the Waterfall support. It's still in alpha but seems to work nicely. I just need to do some work on the y-axis scaling and read the colors from the Sentinel profile.cfg file.
Unzip and copy the files over the originals. Stop ProScan 1st.
KC1UA
The Grinch Who Stole Your SDS150
Works well and pretty smooth with the SDS200 and the USB connection. I expected it might need the LAN connection for the 200 to maximize performance.
Now, I'm going to be "that guy" for a moment (apologies in advance).
Is there any chance, or is it even feasible, that this could develop into a larger screen "point, click, and tune" kind of thing? That would be beyond outstanding.
I realize it's early alpha and I do realize that I can resize the screen when in display only mode.
Thanks for adding this. Lots of potential.
bravo14
Polk County FL
I had a question on Quick Key Status? I was making a local FL and and have some surrounding counties in. Say if I want to select certain QK in proscan I don't have to go on scanner and deselect qk I don't need to scan. Is there something I missed? I looked everywhere for that section.
ProScan
Software Provider
Ontario, Calif.
Correct. Write to the scanner for the changes to take effect. If you want to enable or disable a certain sys/dept./site on the fly then you need to use the scanner keypad. This is from the Sentinel (Easier to Read) BCD436/536HP Manual.
System Quick Keys Status Tab This is where you enable your System Quick Keys. Same function as "Set Scan Selection > Manage Quick Key Status > System Quick Key" in the scanner.
Dept/Site Quick Keys Status Tab
This is where you enable your Department and Site Quick Keys.
