ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Was waiting till the UID problems were solved before bringing this up.
I am having the below happening in version 23+ since the first version of 23 was released. All these extra lines showing in the channel window. I can click to another channel and then back and the lines go away. Never had this problem before v23.
ProScan
Software Provider
Ontario, Calif.
I haven't seen that before. I'll wait a while on this to see if anyone else has this same pronlem. Does it happen on the system, department grids too?
Enforcer52
Lake Livingston, TX
yes happens on all of them, usually when you scroll to the right more so than just going to the grid when it is scrolled to the starting column.
ProScan
Software Provider
Ontario, Calif.
Can you send me a Bug Report.
Bug Reporting and Suggestions
Bugs & Suggestions received initially via email are assigned the highest priority
Bug Reporting
If you discover a bug, send an email to support@proscan.org. The advantage of email is so I can ask questions and send you production quality files with additional testing to help fix the bug. The person reporting the bug will get the fix sooner than waiting for the next release. Put "bug" in the Subject line.
Bug Reports - Advise on the following:
  • Product (ProScan, Free Client, or RadioFeed):
  • Version:
  • Scanner type:
  • Scanner firmware version (if applicable):
  • Windows version:
  • Options pertaining to the bug:
  • Describe in detail what the bug is doing or not doing:
cg
Connecticut
Perhaps your antivirus is false positive. If you read back a few posts to the previous page, there are others seeing it and many that are not.
RandyKuff
Lorain, Ohio
@ProScan Windows Defender is blocking saying this is a virus. Not sure if anyone else has seen this .
Perhaps the file on Proscan website has been compromised?
I scanned that file with ESET antivirus...
That file is clean...
My Windows Defender is shutdown.../ I don't use it...
