ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
W1SRD
CA
Windows 11, local account. Flagged Proscan_23_2.exe as having Win32/DefenseEvasion.A!ml. Auto quarantined the executable.
W1SRD
CA
Malwarebytes has nothing to do with this issue. This was caused by Microsoft built-in antivirus. Once they updated a definition file all was well.
Kind of like Crowd Strike :).
CKnobb
Central NY
23.2 is running fine for me, except now have this information showing up above the menu bar. It duplicates what's in the scan window. 23.2 and below did not show that. Not a huge deal. Is there a setting that may have toggled on? I looked in the options and nothing stood out. I'm flummoxed.
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Remove anything in the below indicated field and apply.
eaf1956
Evansville, IN
Just like previous versions....
CKnobb
Central NY
Excellent! Thanks for the tip. My other instances I use for streaming to BCastify have never shown that data...just only when there is a transmission. They are still at 23.1. This instance has an extra -%F at the end, and it shows everything that's scanning, not just transmissions. Cool! Thanks again for the tip.
Jim
CKnobb
Central NY
@CKnobb Proscan has showed that data at the top for years that was very helpful on my server that was running 16 copies of Proscan connected to 16 Uniden Scanners.
My previous editions only show that data when stopped on a transmission. This new instance shows everything being scanned. Looks to be the extra -%F that's been added.
eaf1956
Evansville, IN
I don't mind it now. In fact, I've appended the -%F to my two 23.1 versions used for streaming. (y) I haven't updated them yet so as not to take the stream down.
My goodness, I update firmware, programming and other stuff on the feed scanner. It doesn't take very long. RR probably doesn't even notice it offline for a few seconds.
