ProScan
Software Provider
Ontario, Calif.
Bob
ProScan
Software Provider
Ontario, Calif.
now if we could have a way to assign color codes to tags automatically on the RR database download that would be cool as well
Color Codes are imported now with the trunk frequencies. Is it working? If not, what is the RR sid number of the system?
WX4JCW
Stow, Ohio
no i mean the LED colors, have the ability to assign a color based on service tag - i.e LAW Dispatch = blue/on
so when importing from RR if the software sees a channel with Law Dispatch it could apply a color for the LED, its not a priority but would reduce editing time
ProScan
Software Provider
Ontario, Calif.
I have a question regarding the Record feature. Would it be possible to add a UID column next to the TG column? It seems I'm kinda flipping back and forth trying to find uid for the recording.
Right now I'm working on Database items and next several releases are dedicated to the Database area. So check back with me later on this.
{edit} I don't think I can put a UID column in the Recorder. UIDs can arrive late or not at all or multiple UIDs per recording.
tumegpc
Southern Oregon
Bob ,
a big thank you ! I've been playing with the Favorite Editor and I can't wait to see what other features come along. One question - when I try to "save as" it will not give me an option to save a unique file name. It just defaults to f_list.cfg. Any chance that will change ?
Thanks again, Pio
ProScan
Software Provider
Ontario, Calif.
Bob ,
Thanks again, Pio
The ProScan Favorites Edit works on the Sentinel and Scanner Favorites list. I'm not sure there's a better way of handling the file method at this point. I'm open to ideals. I don't know what purpose changing the f_list.cfg name would serve and it wouldn't be recognized by Sentinel. Also the hpd files are named like f_000001.hpd which is what Sentinel and the scanner uses. Would the hpd file names changed too? I'm open to ideals and always looking to make this the best.
jonwienke
More Info Coming Soon!
VA
Quick question: is it possible to digitally capture audio from a BCD436HP via the USB connection? The only recording option seems to be an analog connection from the headphone jack to a line-in input.
beachside
Melbourne
The USB only provides a connection to the SD card for programming, and charges the radio.
rwier
Phoenix, AZ
Ok, silly question. Do the recent changes to ProScan apply only to the X36HP Series and DO NOT apply to the HP-* Series? At least I can't find the HP-1 or HP-2 option under Select Scanner Model.
JASII
Silent Key
ProScan: Official Software Thread
I just downloaded ProScan 11.8 and I am using it to control my Uniden Bearcat BCD325P2. I have used Butel ARC XT PRO, so I will be comparing and contrasting. Is there currently a way to have ProScan automatically lockout active frequencies, either temporary or permanent lockout, after logging activity in the History Log?
rwier
Phoenix, AZ
Hi Bob,
I had my ProScan installed on a desktop. I also had it installed on at least one laptop, maybe two. The desktop went South. I replaced it with a very similar model. I found my user/key info, and proceeded to download/install ProScan ton the new desktop. When I went to activate the software, I am given three choices, Buy, OK, and Enter Key. I select Enter Key, and am told I have used up all my allowed downloads (3?). I try Buy, and am told
Registration Name Taken - Choose Another
Buy more licences is fine, but not sure how I should proceed?
