ProScan
Software Provider
Ontario, Calif.
Bob
mancow
N.E. Kansas
I went to lunch with the laptop running. When I came back an hour later the recorder is not working again. History logging is working normally and jumping to active entries in the grid but the recorder tab does not highlight or indicate anything is being recorded.
mr10pt
Lowell, IN
When you say "the recorder function turns itself off." Does that mean the Recorder button is changing to a "Pressed Out" effect? That shouldn't happen.
Could the root cause be more like the serial port or sound device going to sleep?
Are you using a scanner with WiFi or LAN audio?
Using LAN. The Record button when on has a gray background. When off, turns white like the others. Any recommendations how to check serial port or sound device? Windows 10. Before I checked the Lookup Record Flag option, the recorder stayed on and recorded everything, including marked channels.
ProScan
Software Provider
Ontario, Calif.
Perhaps it's the LAN. I would Google "lan sleep mode disable"
{edit} If using the LAN for the data then the Serial Port is not involved and no need to check that. Same with the sound card.
mr10pt
Lowell, IN
It was the LAN. Ran several checks to verify before replying. All is good and recording as set. Once again thank you for your help and this awesome product!
GTR8000
NY/NJ Database Guy
BEE00
I'm not to sure what OFT is. I tried to look it up and I only seen something dealing with DMR but this system is p25p1
One Frequency Trunk. Program the channel as a P25 One Frequency "system" and you will then see any UID in use. You will not be able to see that info if you program it conventionally.
Reconrider
Inside the Galaxy
Radio Galaxy
I think I finally figured out how to do the OFT. Just have to upload and test.
I'm still new to the sds100 so I'm always learning -
Reconrider
Inside the Galaxy
Radio Galaxy
I think I'm setting it up wrong. I set it up and it says nothing to scan but it is turned on. Can you show me how to set it up please? thanks
edit: @fxdscon
jonwienke
More Info Coming Soon!
VA
Did you populate the location coordinates and service radius settings for the department(s) and site(s)? If location control is on and you don't populate those fields, the scanner thinks they are in the middle of the Atlantic Ocean and will never scan them.
druhe
Southwest Pa
How can I download version 16.6 ? I go directly to the download page and keep receiving:
This site can’t be reached
The connection was reset
ProScan
Software Provider
Ontario, Calif.
It works here.
druhe
Southwest Pa
