ProScan
Software Provider
Ontario, Calif.
Bob
JASII
Memory Capacity
#1 says 464.075000 SLOT 2 COLOR CODE 15
#2 says 464.075000 SLOT 1 COLOR CODE 15
#3 and #4 are bad data would be the way I see it.
When I checked this morning, LCN Finder showed LCN 2 for 464.075000.
However, since both CAP+ and IDS/NX4 are displayed, I am not sure which system LCN 2 is affiliated with.
I think my next move will be to create two different systems. One CAP+, with 464.075 and LCN 2. The other with IDAS, with 464.075 and LCN 2. Which ever one has active talkgroups will get my vote.
mswells
WB6JLB
Phoenix, AZ
Just recently replaced my router, and I am able to connect to proscan, and broadcast my feed along with url audio, onto broadcastify, but the Proscan DISPLAY IS BLANK....any ideas why ?
ProScan
Software Provider
Ontario, Calif.
I take it that the data(display) is using the Ethernet. Go to the menu Comm Port and click on the URL Setup button. Click the Auto Detect IP Scanners button then see if the scanner shows in the list.
Reconrider
Inside the Galaxy
Radio Galaxy
Did you hook the scanner to the computer? Did you go to the "Comm port" up top and select your serial port being used by the scanner?
If you did that all and it's not working, power off then back on the scanner and make sure you click "yes" for serial port use.
kmartin
Galveston, Texas
ProScan
Bob
Make a better one for whistler !
ProScan
Software Provider
Ontario, Calif.
Hello All,
The next version is changing from the .NET Framework 2.0 to 4.8. I need this tested before the final release. I spot tested it and found zero issues but need to know for sure. Win XP is not supported with this framework.
  • Added - Custom Formatter %SI-Site Name to the BCDx36HP & SDSx00 scanner types.
  • Changed - ProScan now targets the .NET Framework 4.8. Win 7 SP1 and above supported.
This is called version 17.1 but it's not the official 17.1 release. Please send any bug reports via email so I can send test files until fixed.
https://proscan.org/ProScan_17_1.zip
eaf1956
Evansville, IN
Hello All,
How about WIN 7?
Moose
New Jersey
Below is a screenshot of my problem. Scanner is recording pefectly for 2 towns, Newark & Verona. But for whatever reason North Caldwell is grayed out every morning when I check. I'm not around when that town is transmitting so I'm not sure what is coming out of the speaker. I can't see anything that would cause this.
Synchro39
Montreal Quebec
make the name of this system shorter i had same problem and solved this issue after changing the name
