ProScan
Software Provider
Ontario, Calif.
Bob
StoliRaz
£uck Encryption
Updated to 23.5 this morning, Windows 11 (Windows defender) quarantined it as severe threat
Detected:Behavior:Win/Execution.A!ml
file:C:\ProScan\ProScan.exe
Odd. I rolled back to 23.4 which had no issues with W11 security. Not sure if it's a known issue or what, searched and couldn't find anything. Just thought I'd bring it to your attention.
Chris0516
Pittsboro, North Carolina
23.5 works fine for me.
yorky
Hi All, I’ve noticed that running a lot of files/folders with the web server has a high CPU usage. Is there any way other than to trim the files to get a lower CPU usage?
I’ve also been running an old version 14 for a long time, and updated to the latest now. But when playing back in the recorder, it can take a good two seconds to play the file after clicking play. If you select a bunch of recordings, it always pauses a good two seconds between each one. Any ideas to make it playback immediately like the older version?
lesabob
Schuylerville, NY
Had same issue and was advised to add an exception. Nothing wrong with the software
